Page 1 of 3 1 2 3
what's wrong with 59* sb's #1708359
12/08/14 10:32 PM
12/08/14 10:32 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
I see alot of complaining about 59* blocks and how the Victor head could be better utilized on a different block
How many guys need more then 8000rpm w a 420+ ci motor ?
The 59* stuff works fine for 98.9 % of what guys wanna do out there.
This is what went in nascar and went 500laps in heat and at high rpm..
Just sayin
Re: what's wrong with 59* sb's [Re: fishy340] #1708360
12/08/14 10:45 PM
12/08/14 10:45 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would like too see your indy's and a new victor on the same flow bench to see who is king.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: what's wrong with 59* sb's [Re: fishy340] #1708361
12/08/14 11:03 PM
12/08/14 11:03 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Just sayin
A pliers will loosen a nut too.
Is it the best tool for the job ?
No doubt , you can make a stout 59 degree small block.
But at the point where these heads ( if the flow numbers bear out ) go to work is the point where the stock block becomes marginal.
Will it work ?
Probably.
But rounding off the corners at that point gets pretty pricey.
Re: what's wrong with 59* sb's [Re: tubtar] #1708362
12/08/14 11:28 PM
12/08/14 11:28 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
As it is said elsewhere, "in on one".
Re: what's wrong with 59* sb's [Re: cudadoug] #1708363
12/08/14 11:59 PM
12/08/14 11:59 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
Their are of course limitations but how many push to that limit ?
The head choice is limited but not like before w9,victors and stuff like this came out.
As far as a stock block goes FILL IT they are tuff sobs them 340's...:)
Brad my indy were below 330cfm but it suprised me on the power it makes.
Re: what's wrong with 59* sb's [Re: fishy340] #1708364
12/09/14 12:02 AM
12/09/14 12:02 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Totally agree. 59 will take more pounding than people think. Seems everyone talks about how weak the stock blocks are. ...but I hear of very few being broke because of power.
Re: what's wrong with 59* sb's [Re: fishy340] #1708365
12/09/14 12:04 AM
12/09/14 12:04 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Put em on a magnum block, they are stronger than any stock LA blocks ever were and there is 550-600 hp 340 blocks surviving
It would not live up to the heads potential but it beats full ported RPMs that seem to stop around 600 in serious effort engines. The victor would just be getting started.
To help with the 59* lifter issue I prefer a higher ratio rocker to straighten the lifter/PR angle slightly and access flow faster. It is a small crutch for a *59 engine but the shallower valve angle is going to help also by tilting the top of the valve away from the intake.
Of course my favorite option is to stuff a 4.25 crank in there to bring the RPM down.
Re: what's wrong with 59* sb's [Re: fishy340] #1708366
12/09/14 12:23 AM
12/09/14 12:23 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
In before purple cams
Fishy's car impresses me BTW.
Re: what's wrong with 59* sb's [Re: fishy340] #1708367
12/09/14 12:26 AM
12/09/14 12:26 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mine from Ryan went 346@700 if I remeber. But like I said I would like to see them on the same bench at the same time.
Re: what's wrong with 59* sb's [Re: SpareParts] #1708368
12/09/14 12:30 AM
12/09/14 12:30 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
"IF" the Ebrock head would have come out in a timely manner I'd still be playing with concrete filled stock blocks. I was more than happy with the performance of our W5 program.....but not much else with them.
Re: what's wrong with 59* sb's [Re: 1967dartgt] #1708369
12/09/14 12:34 AM
12/09/14 12:34 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Mine from Ryan went [Email]346@700[/Email] if I remeber. But like I said I would like to see them on the same bench at the same time.
I got a set of 360-1's they are the cnc 245's but the raised port vesion. Ryan did them and said they more around 255cc and I remember a set he did on here in the 365 @ .700" lift range. I also have a magnum block and T&D 1.7 shaft rockers. I have the MRL Performance offset lifters and spin mine to 8K with no issues.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: what's wrong with 59* sb's [Re: slammedR/T] #1708370
12/09/14 12:44 AM
12/09/14 12:44 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
So you can run offset lifters on a 59 degree block? I inquired about this a while back and several chimed in and said the link bars would snap almost immediately.
Re: what's wrong with 59* sb's [Re: 496 A-body] #1708371
12/09/14 12:49 AM
12/09/14 12:49 AM
slammedR/T Offline
slammedR/T  Offline
the comps will snap the link bars because they can't handle the twist force from the lifter angle. The MRL's have a WAY! stronger link bar and they way they are linked together is stronger. I have run mine for awhile now till I had a sleeve failure(my factory block was sleeved in 04) and then a cracked head(which is fixed now thank god). More time slips to come. Thought I had oil pressure issue with them but i figured out that problem.
racemagnum
Re: what's wrong with 59* sb's [Re: slammedR/T] #1708372
12/09/14 01:56 AM
12/09/14 01:56 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
So who wants to get rid of some W9RP rocker arms? I've got some crap laying around to have some 59* fun!
Re: what's wrong with 59* sb's [Re: SpareParts] #1708373
12/09/14 02:03 AM
12/09/14 02:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I sold off all my W-9 stuff when I sold my W-9 engine..
all I have now is W2s and W-5s on stock LA blocks
till I start my gen3
Re: what's wrong with 59* sb's [Re: MR_P_BODY] #1708374
12/09/14 02:05 AM
12/09/14 02:05 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Thanks for the help! LOL
Do ya know of any? Maybe you got some lunch box items from Mopar?? Lol
Re: what's wrong with 59* sb's [Re: SpareParts] #1708375
12/09/14 02:08 AM
12/09/14 02:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Nope.. I dont know of any... hell I've been retired
for 6 years now
Re: what's wrong with 59* sb's [Re: fishy340] #1708376
12/09/14 12:15 PM
12/09/14 12:15 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Fishy340;
In short, what is wrong with the 59*, is answered and fixed with the 48* blocks.
I am unamused with the prices to play with them.
Re: what's wrong with 59* sb's [Re: 1967dartgt] #1708377
12/09/14 01:41 PM
12/09/14 01:41 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
i would like to see a pair on a stock block and sit next to me lol
Re: what's wrong with 59* sb's [Re: Rob C] #1708378
12/09/14 02:34 PM
12/09/14 02:34 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
Rob I do understand the 48* stuff having some advantage but like I said how many really really need that much.
I personally think close to 800 could be had reliably and dependable w 59* stuff (Max Effort)...w a resto or R block.
Page 1 of 3 1 2 3
