Opinions on engine noise please #1707640
12/07/14 12:09 PM
12/07/14 12:09 PM
Massachusetts
Row_your_own Offline OP
Massachusetts
383 with what sounds like either piston slap or rocker noise?
1969 Plymouth Road Runner C-179280: http://youtu.be/RAhpJZo6geE
1968 Road Runner 383 4-speed
Factory BB1 black on black
Re: Opinions on engine noise please [Re: Row_your_own] #1707641
12/07/14 02:22 PM
12/07/14 02:22 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Just a guess, but to me it sounds like piston slap. I have a 400 that sounds similar to that just not quite as bad. I hate it because the car sounds cool out back, then you walk up to the hood and it sounds like a diesel.
Re: Opinions on engine noise please [Re: Row_your_own] #1707642
12/07/14 02:27 PM
12/07/14 02:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I've never heard piston slap so I can't say but that does not sound good. I could almost be rockers hitting the baffles but there would have to be a big cam and adjustable rockers for that ???
Re: Opinions on engine noise please [Re: 440newport] #1707643
12/07/14 02:27 PM
12/07/14 02:27 PM
Massachusetts
Massachusetts
Yea, I was leaning towards piston slap. Ugh...
Re: Opinions on engine noise please [Re: JohnRR] #1707644
12/07/14 02:31 PM
12/07/14 02:31 PM
Massachusetts
Massachusetts
at first blush I thought is was rocker noise. Almost like shafts put on incorrectly. Exhaust note is mild so large cam out of the equation. It's too bad, its a pretty clean car. Too much money with a suspect engine.
Re: Opinions on engine noise please [Re: Row_your_own] #1707645
12/07/14 02:37 PM
12/07/14 02:37 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
piston slap is a knocking sound. depending on the material the piston is made out of can have an effect on how pronounced the noise is. piston slap is a given with a high performance piston with a straight pin. if noise goes away as engine temperature increases and the engine does have a straight pin piston, then i wouldn't get my panties in a bunch over it.
i tried to listen to the video, gave up after 2 minutes. why would you ask somebody to diagnos a noise with the music blairing!
Re: Opinions on engine noise please [Re: Row_your_own] #1707646
12/07/14 02:39 PM
12/07/14 02:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it quiets down after 3 or 4 minutes or so, It would be pistons rocking around in the bores. It does sound a little extra loud even so. If it does quiet when warmed completely, it may run for many years like that.
Re: Opinions on engine noise please [Re: lewtot184] #1707647
12/07/14 02:45 PM
12/07/14 02:45 PM
Massachusetts
Massachusetts
car isn't in my possession but thanks for the effort.
Re: Opinions on engine noise please [Re: Row_your_own] #1707648
12/07/14 07:22 PM
12/07/14 07:22 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
rule #1 - in considering buying (from a dealer) is beware.
with that, I'd recommend a trip to inspect what you are considering or thorough inspection of the car by a qualified shop of your choice.
Re: Opinions on engine noise please [Re: Row_your_own] #1707649
12/08/14 02:14 PM
12/08/14 02:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
why would you say ugggh , rockers hitting the covers is an easy fix that doesn't require rebuilding the engine ...
Hopefully you aren't stupid enough to buy this car sight unseen?
Re: Opinions on engine noise please [Re: JohnRR] #1707650
12/09/14 06:18 PM
12/09/14 06:18 PM
Massachusetts
Massachusetts
Your answer to first question is I was saying ugh in regards to assumption that noise is piston slap, not the rockers hitting the baffles.
Second question, before I spend $350.00 to have car inspected I asked for opinion, not diagnosis on engine noise.
Re: Opinions on engine noise please [Re: Row_your_own] #1707651
12/09/14 06:46 PM
12/09/14 06:46 PM
NE
moparpoolman Offline
NE
I have a 440 that has piston slap when cold and even when it gets up to temp it still makes the noise until it's driven. I would test drive the car after it's to temp and get on it hard through the gears. After a hard drive the noise should go away or be much less if it's piston slap.
Re: Opinions on engine noise please [Re: Row_your_own] #1707652
12/09/14 08:13 PM
12/09/14 08:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
An opinion is like a diagnosis in this case I would think ??????
Good luck ...
Re: Opinions on engine noise please [Re: Row_your_own] #1707653
12/09/14 10:50 PM
12/09/14 10:50 PM
NE
NE
I once drove all the way to MN to buy a car which was suppose to be in great condition and had a Galen report that sounded great. After driving 22hrs with my truck and trailer, I saw the car in person and knew within minutes I wasn't buying the car. Drove another 22hrs home, 1 nap for 4 hrs along the way. It was a long 48hrs. Yes it was a big waste of money going there but THANK GOD I didn't buy it sight unseen! If you have to, fly there, rent a car, see it, and make your decision.
Re: Opinions on engine noise please [Re: moparpoolman] #1707654
12/10/14 12:17 AM
12/10/14 12:17 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Engine noise??? yes it has. Cause?? to be determined.
The car looks OK in the video but has several OBVIOUS flaws besides the "engine noise"
Depending on the price it may or may not be worth pursuing. As someone stated if its at a Classic car dealer
Re: Opinions on engine noise please [Re: TJP] #1707655
12/10/14 03:28 AM
12/10/14 03:28 AM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
HELL-O? Obvious!! DUH.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
