Page 3 of 4 1 2 3 4
Re: Victor small block Mopar head updates. [Re: WHITEDART] #1707605
12/08/14 08:14 AM
12/08/14 08:14 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
now T&D is making a nice rocker arm for the hemi.and harlem sharp has a new version seems to work well.I don't think it's fair that we compare a performance w series or aftermarket Indy head to a production Gen 3
That's my point. I was just hoping someone had ETs to share from an apples to apples to comparison between the two.
Re: Victor small block Mopar head updates. [Re: GTS340] #1707606
12/08/14 10:30 AM
12/08/14 10:30 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Wasn't the one who came in edelbrock victor head post and said hemi heads flow just as much as them stock. Wasn't the one who asked for a combo when some said a old design indy head out proformed them, just show a running combo. Now you want a apple to apple or a 2000 cad designed head compaired to a 1950(?) designed head. LOL hope something improved in the past 50 years.
How much do these rockers cost and what kind of lift can you run with them?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Victor small block Mopar head updates. [Re: 1967dartgt] #1707607
12/08/14 01:04 PM
12/08/14 01:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The Gen3 stuff will be no different than the LA stuff..
given some time the Gen3 will have plenty of parts
and will out perform the LA... they didnt come out
with a W series head for years after the LA came out..
the gen3 stock block will take more power than a stock
LA block now
Re: Victor small block Mopar head updates. [Re: MR_P_BODY] #1707608
12/08/14 01:34 PM
12/08/14 01:34 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
The gen 3 won't have the benefit and R$D of been used in places were money is no object like w stuff Has had in sprint, nascar,pro stock.It will take time but they will come a round.people are still trying to figure out how to make them work the good thing is its a small block
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Victor small block Mopar head updates. [Re: WHITEDART] #1707609
12/08/14 09:46 PM
12/08/14 09:46 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Nice to know there hopefully will be another option, for people like me with 59* R block based iron.
Re: Victor small block Mopar head updates. [Re: Leigh] #1707610
12/08/14 11:24 PM
12/08/14 11:24 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
I spoke to one of the guys at Hughes, and he told me that Edelbrock sent them a CNC ported head to put on their flow bench. He thought it has 2.12 intake valves, and they only have the one. Supposedly they are going to be available in January.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Victor small block Mopar head updates. [Re: DconD100] #1707611
12/08/14 11:28 PM
12/08/14 11:28 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
Combustion chamber volume 58cc
Intake runner volume 225cc
Exhaust runner volume 62cc
Intake valve diameter 2.15"
Exhaust valve diameter 1.60"
Valve stem diameter 11/32"
Valve guides Manganese bronze
Deck thickness 5/8"
Valve spring diameter 1.55"
Valve spring maximum lift .650"
Rocker stud N/A
Guideplate
N/A
Pushrod diameter 5/16"
Valve angle 16°
Exhaust port location Raised
Spark plug fitment 14mm x 3/4 reach, gasket seat
Made In USA
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Victor small block Mopar head updates. [Re: pittsburghracer] #1707612
12/08/14 11:47 PM
12/08/14 11:47 PM
Pa
Hot 340 Online content
Hot 340  Online Content
Pa
That w5 exhaust pattern is a real kick in the nuts. With all the w2 headers for Indy floating around you would think... ahhh never mind.
Re: Victor small block Mopar head updates. [Re: Hot 340] #1707613
12/09/14 12:03 AM
12/09/14 12:03 AM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
Who will be at the PRI show? please if you can get some pics because the wait on these heads has left me feeling like a donkey with a carrot hung out in front.
Re: Victor small block Mopar head updates. [Re: Hot 340] #1707614
12/09/14 12:34 AM
12/09/14 12:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...I was counting on that to help sell my TTI W5 headers!
Re: Victor small block Mopar head updates. [Re: pittsburghracer] #1707615
12/09/14 12:36 AM
12/09/14 12:36 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Deck thickness 5/8"
Rocker stud N/A
Guideplate
N/A
Valve angle 16°
Made In USA
This is the head to run in ultra if it flows anywhere close to what they say.
Re: Victor small block Mopar head updates. [Re: 1967dartgt] #1707616
12/09/14 12:40 AM
12/09/14 12:40 AM
PA.
"Little"John
"Little"John
PA.
Deck thickness 5/8"
Rocker stud N/A
Guideplate
N/A
Valve angle 16°
Made In USA
planning on a big block at this time UNLESS I happen to find a GOOD block.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Victor small block Mopar head updates. [Re: pittsburghracer] #1707617
12/09/14 12:48 AM
12/09/14 12:48 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Deck thickness 5/8"
Rocker stud N/A
Guideplate
N/A
Valve angle 16°
Made In USA
With the 16* valve angle you fall into the plus or minus 2* rule from stock. So you can run these at a stock valve angle weight. So a r3 at 440 cu inch with these heads could be 3050 lbs.
Re: Victor small block Mopar head updates. [Re: pittsburghracer] #1707618
12/09/14 12:52 AM
12/09/14 12:52 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
If they ever get done I will do CNC program for them.
Had one in my hand last year and was not impressed
Exhaust port will be good intake not so much...
So flow number look backwards to me ????
I would think more like 330-350 intake and 250-265 ex.
And Brads right would be the Mopar head to have in ultra but is 16* valve angle get the stock head break???
Re: Victor small block Mopar head updates. [Re: W5DART66] #1707619
12/09/14 12:58 AM
12/09/14 12:58 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Heavy weight is 15* and down.
Re: Victor small block Mopar head updates. [Re: W5DART66] #1707620
12/09/14 02:23 AM
12/09/14 02:23 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Under 15* gets hit with weight...me and Brad only have to be 3200...smh
Re: Victor small block Mopar head updates. [Re: fishy340] #1707621
12/12/14 08:34 PM
12/12/14 08:34 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
So did the heads make it to the PRI show?
Re: Victor small block Mopar head updates. [Re: moparclown] #1707622
12/12/14 08:49 PM
12/12/14 08:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what heads?
Re: Victor small block Mopar head updates. [Re: Quicktree] #1707623
12/12/14 10:05 PM
12/12/14 10:05 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
what heads?
those heads
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Victor small block Mopar head updates. [Re: slammedR/T] #1707624
12/12/14 10:15 PM
12/12/14 10:15 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
can you roll your W8/9 head back one degree to get the weight break. that is kind of stuff they do out here.
Page 3 of 4 1 2 3 4
