How much stroke 426 Hemi with stock oil pan ? #170755
12/19/08 03:56 PM
12/19/08 03:56 PM
Slidell, La.
doctor_mopar Offline OP
Slidell, La.
We are building a Hemi with a stock block, and would like to stroke it with either a 4.125 or even a 4.250 crank with the big block chevy rod journal size. We would like to be able to use a stock hemi oil pan, with a milodon windage tray for a stroker, and stock internal pick up and oil pan. ANYONE DONE THIS, WILL IT CLEAR AND FIT ? Thanks, Ron
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: How much stroke 426 Hemi with stock oil pan ? [Re: doctor_mopar] #170756
12/19/08 04:10 PM
12/19/08 04:10 PM
Canada
CrAzYMoPaRGuY Offline
Canada
The crate engines are 4.15 cranks.
Mine is a 4.15 crank but an aftermarket pan, but it has an internal pickup tube. I don't see what problems a stock pan would pose with the 4.15 to be honest.
CrAzYMoPaRGuY
Re: How much stroke 426 Hemi with stock oil pan ? [Re: doctor_mopar] #170757
12/19/08 04:57 PM
12/19/08 04:57 PM
California
mickm Offline
mickm  Offline
California
mine is a 4.15 crank with a stock windage tray and oil pan. i never looked at the clearance, but i don't think a 4.25 would be an issue either. don't know if 4.25 requires grinding the block for clearance though. 4.15 doesn't.
Re: How much stroke 426 Hemi with stock oil pan ? [Re: doctor_mopar] #170758
12/20/08 12:56 PM
12/20/08 12:56 PM
Slidell, La.
Slidell, La.
Thanks guys !
Re: How much stroke 426 Hemi with stock oil pan ? [Re: doctor_mopar] #170759
12/20/08 02:56 PM
12/20/08 02:56 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Mine has a 4.5 stroke with the chevy rod journal. Does have an aftermarket pan though but I think about anything that will clear the oil pickup tube will clear the stock pan. Might have to lose the windage tray.
Re: How much stroke 426 Hemi with stock oil pan ? [Re: Silverbullet2] #170760
12/20/08 03:08 PM
12/20/08 03:08 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
the biggest challenge is getting the crank to clear the pick up tube. the pan is no problem.
i have a 4.75 stroke crank, with chevy rod journals, in a mopar performance siamese block with a internal oil pick up tube.
perception is 90% of reality
Re: How much stroke 426 Hemi with stock oil pan ? [Re: Mr T2U] #170761
12/20/08 03:34 PM
12/20/08 03:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Big Gun!!!
Re: How much stroke 426 Hemi with stock oil pan ? [Re: doctor_mopar] #170762
12/20/08 05:03 PM
12/20/08 05:03 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It will work with a 4.25 arm and 32000 tray. Might need to clearance the pick-up boss and/or tube.
Re: How much stroke 426 Hemi with stock oil pan ? [Re: BSB67] #170763
12/21/08 08:25 AM
12/21/08 08:25 AM
Slidell, La.
Slidell, La.
Thanks ! I just wanted a good feeling before we order parts, and get something that would't work like we want !
