Re: How much stroke 426 Hemi with stock oil pan ?
[Re: doctor_mopar]
#170756
12/19/08 04:10 PM
12/19/08 04:10 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
The crate engines are 4.15 cranks.
Mine is a 4.15 crank but an aftermarket pan, but it has an internal pickup tube. I don't see what problems a stock pan would pose with the 4.15 to be honest.
CrAzYMoPaRGuY
[Re: Silverbullet2]
#170760
12/20/08 03:08 PM
12/20/08 03:08 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
the biggest challenge is getting the crank to clear the pick up tube. the pan is no problem. i have a 4.75 stroke crank, with chevy rod journals, in a mopar performance siamese block with a internal oil pick up tube.
perception is 90% of reality
[Re: Mr T2U]
#170761
12/20/08 03:34 PM
12/20/08 03:34 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Big Gun!!!
[Re: doctor_mopar]
#170762
12/20/08 05:03 PM
12/20/08 05:03 PM
Posts: 4,315 Prospect, PA
BSB67
Prospect, PA
We are building a Hemi with a stock block, and would like to stroke it with either a 4.125 or even a 4.250 crank with the big block chevy rod journal size. We would like to be able to use a stock hemi oil pan, with a milodon windage tray for a stroker, and stock internal pick up and oil pan. ANYONE DONE THIS, WILL IT CLEAR AND FIT ? Thanks, Ron
It will work with a 4.25 arm and 32000 tray. Might need to clearance the pick-up boss and/or tube.
