2001 Ram 1500 4x4. My truck is mint, you could eat off of it anywhere. These brakes have never been apart.
What Rhino is to transmissions, Grizzly is to the straight-axle Ram.
While having this straight-axle POS apart (AGAIN
) and replacing half of it, I noticed ONE of the front brake pads on the passenger side is getting close to done. It's the piston side pad.
The other pad is about 40% and the driver side is wearing even at about 40% too.
So, I put new pads on both sides, went for a drive and my passenger side is holding.
I cracked the bleeder and nothing came out. If I tap on the caliper brake fluid will come out.
So, what is it? Brake hose or caliper? I have to ask because my Partsman is going to quit getting me anything if I keep returning stuff that doesn't cure the problem.
Thanks.
