Re: Custom Pistons [Re: 69dart] #1707256
12/06/14 09:53 PM
12/06/14 09:53 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
for bracket racing, why are you making it difficult?
10.00 motor vs 9.60 motor, does one pay better than the other?
See what the cylinders need to get them straight then find a shelf piston to fit that's in the that range.
Re: Custom Pistons [Re: nss guy] #1707257
12/06/14 10:06 PM
12/06/14 10:06 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Here is the problem with the 383, with it's short stroke a dome piston is necessary to achieve adequate compression, with the HEAVY TRW/SPEEDPRO L2293 being discontinued there are no forged 383 dome pistons that I have seen from any of the popular manufacturers, making a custom piston pretty much a necessity. I prefer custom pistons in everything I do anyway!
Re: Custom Pistons [Re: GTS340] #1707258
12/10/14 01:33 AM
12/10/14 01:33 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Racetec Custom pistons are nice and working great in my 582 with a fogger .
Re: Custom Pistons [Re: 69dart] #1707259
12/10/14 04:33 AM
12/10/14 04:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm starting the process of building a new 383 for the roadster. Since it doesn't look like anyone makes forged dome pistons for a 4.28 or 4.31 bore with a 1.32 compression height it looks like I may need to order a set of custom pistons. I basically need the Ross 99499 in a 4.28 bore.
What's everyone's favorite source and what kind of price can I expect?
I have a set of the pistons you are looking for, what stroke are you planning on building?
The piston is a custom Diamond with an effective 9.9cc dome , 4.280 bore, 1.32 CH, CNC lightened , coated skirts and ceramic coated top , they cost me $1100 when I bought them back in 06.
Re: Custom Pistons [Re: JohnRR] #1707260
12/10/14 01:57 PM
12/10/14 01:57 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Man you guys got off easy. Diamond has quoted me a whole lot more for the set of slugs for the 496. Damn rings were $400 just by themselves. Pins another $200, cause my old ones were squarshed. And I ain't getting no fancy coatings either.
Re: Custom Pistons [Re: Airwoofer] #1707261
12/10/14 02:53 PM
12/10/14 02:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I can't remember if that included the pins, but did include the shipping ... and it was 8 years ago.
Re: Custom Pistons [Re: JohnRR] #1707262
12/10/14 03:03 PM
12/10/14 03:03 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
I don't know what Diamond's are on special order. But I just got some made by Ross with my C/H, Valve notch depth and diameter, F/T for $824 at my door. Not that much more than a shelf piston.Took 14 days from the time I called them they were here.
That was with no pins. :
Re: Custom Pistons [Re: 69dart] #1707263
12/10/14 03:59 PM
12/10/14 03:59 PM
Des Moines Iowa
Bickel Motors Offline
Des Moines Iowa
I have a set of Arias pistons with pins and rings. 4.28 Bore. Pm me or e-mail me bickelmotors@hotmail.com
Re: Custom Pistons [Re: Bickel Motors] #1707264
12/10/14 07:14 PM
12/10/14 07:14 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Thanks for all the responses!!
I'm waiting for the engine builder to decide what bore it will take to clean up the block I dropped off last week. As soon as hear from him I'll know what the next will be.
Does anyone know what is the typical max bore for a 383 block? I'm guessing 4.31 but at 4.31 why not go to 4.32 and use a 440 piston? I haven't researched if there is rod available for that combo just thinking aloud.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Custom Pistons [Re: JohnRR] #1707265
12/10/14 11:17 PM
12/10/14 11:17 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
The Diamond pistons I bought this winter did not come with pins. I used my old ones.
Re: Custom Pistons [Re: Bigcube] #1707266
12/11/14 05:22 AM
12/11/14 05:22 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
You may want to check my post in the "New products" section.
Leave the gun.......take the Cannoli's....Mike
Re: Custom Pistons [Re: 69dart] #1707267
12/11/14 11:37 AM
12/11/14 11:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There is no set in stone number for max bore for any block, you need to have it sonic checked to see what the block you have is capable of being bored to.
As far as just take it to 4.320 and use a 440 piston , there are very few, if any , 440's being built on a standard bore considering the last 440 was produced over 2 decades ago, so you probably would be hard pressed to find a shelf stock 440 piston that would work, remember that outside of the 6pk piston , there is no stock , short CH , 440 piston with valve reliefs so thinking you can use a 440 piston shouldn't even be considered.
