66/67 vs 68-70 b-body frame? #1707059
12/06/14 12:18 AM
12/06/14 12:18 AM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Just finally got around to watching the episodes of Powerblock (or whatever they're calling it now. Why DID they change all the names?) With the G Machines chassis. I would absolutely love to have one of those under my 67. I doubt I could ever afford one, but Schwartz's website only mentions 68-70. I thought underneath 66-70 was the same. If not, what's different?
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: 66/67 vs 68-70 b-body frame? [Re: closer9] #1707060
12/06/14 01:37 AM
12/06/14 01:37 AM
Marion, Ohio USA
kab69440 Offline
kab69440  Offline
Marion, Ohio USA
I understand them to be the same as well. I can tell you from personal experience that a 66 Charger console needs an extra two inches of clearance notch at the rear of rear floorpans where they transition to the underseat pan when installed in a 69 Charger. Either the 66 floor is longer or the 69 front console mounts are farther rearward.
Just because you're paranoid, it doesn't mean they are not out to get you. WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
Re: 66/67 vs 68-70 b-body frame? [Re: closer9] #1707061
12/06/14 02:09 AM
12/06/14 02:09 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Idler arm mount is different...that is the largest difference.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 66/67 vs 68-70 b-body frame? [Re: astjp2] #1707062
12/06/14 02:35 PM
12/06/14 02:35 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Interesting. Doesn't seem like either would prevent using the G Machines chassis. Maybe they just haven't tried it on a 66/67 yet.
If they ever come looking for volunteers, I'll be the first in line!!! The main issues I always have with my 67 are steering and brakes, and their setup would address both.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: 66/67 vs 68-70 b-body frame? [Re: closer9] #1707063
12/06/14 05:41 PM
12/06/14 05:41 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
66-67 are a bit narrowed than 68-70. Not by a lot but just a bit Could you make a Schwarzt frame fit, probably, but it might need to some wheel opening modifications and more offset on the wheels to keep them under the openings.
BTW, once you spec out one of those Schwartz units with suspension, brakes, etc, expect to be up around $25k.
Re: 66/67 vs 68-70 b-body frame? [Re: TC@HP2] #1707064
12/06/14 06:25 PM
12/06/14 06:25 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Yep. That's why I'll most likely never have one under my car...
Thanks for the info. Didn't know they were narrower.
Daily:
'19 Frontier 4WD
Belle:
Other:
