A-body driveshaft loops
#1706624
12/04/14 03:06 PM
12/04/14 03:06 PM
Posts: 66 PENNSYLVANIA
CERTIFIABLE_HEMI
PENNSYLVANIA
Are the A-body aluminum driveshaft safety loops still made that attach to the transmission crossmember, and if so who sells them? They were sold on e-bay at one time. Just can't remember who it was. Thanks!
Re: A-body driveshaft loops
[Re: CERTIFIABLE_HEMI]
#1706629
12/04/14 06:00 PM
12/04/14 06:00 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
I have an aluminum one for a B-body and it is considerably lighter than steel. Just need one for the Pure Stock races, so I'm not concerned if it's NHRA legal.
It may be considerably lighter than steel but it would be interesting to see what it , and the floor pan , looks like should the shaft do the unthinkable.
Where did you get the B body one ?
#1706631
12/05/14 12:37 AM
12/05/14 12:37 AM
Posts: 506 Utah, USA
1964superstock
Utah, USA
1967-1976 A-Body (Duster, etc) Metco's one-piece driveshaft safety loop is custom-designed to fit the floor pan of the 1967-1976 MoPar A-Body. The ring is made from seamless DOM steel in an oversize dimension to accommodate lowered vehicles and aftermarket driveshafts. The flanges are laser-cut from heavy-duty steel and the assembly is precision-welded in a fixture. The finished loop is powdercoated black and packaged with installation instructions and Grade 8 hardware. This driveshaft loop is designed to mount to the floor pan within six inches of the front universal joint, with the loop oriented up in the transmission tunnel. Installation requires that the user add four holes to the floor pan for the provided mounting bolts. Installation instructions are included. http://www.metcomotorsports.com/proddetail.asp?prod=MDL1600
[Re: 1964superstock]
#1706632
12/05/14 01:24 AM
12/05/14 01:24 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
There was a guy on Ebay selling aluminium drive shaft loops for mopars....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
#1706634
12/05/14 02:24 AM
12/05/14 02:24 AM
Posts: 22,696 Bitopia
jcc
Bitopia
An Alum driveshaft safety loop IMO ranks right up there with an Alum roll bar. Can be done, I sure would not do it, and likely not legal anywhere. Save weight with an alum DS first if that is the objective, which would give an Alum safety loop a fighting chance.
[Re: jcc]
#1706635
12/05/14 02:37 AM
12/05/14 02:37 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Aluminum driveshaft is likely to reduce rotational inertia if the diameter or thickness isn't increased too much. Aluminum driveshaft loop should be low on the weight savings list of things to do.
#2414531
12/07/17 01:29 AM
12/07/17 01:29 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
1967-1976 A-Body (Duster, etc) Metco's one-piece driveshaft safety loop is custom-designed to fit the floor pan of the 1967-1976 MoPar A-Body. The ring is made from seamless DOM steel in an oversize dimension to accommodate lowered vehicles and aftermarket driveshafts. The flanges are laser-cut from heavy-duty steel and the assembly is precision-welded in a fixture. The finished loop is powdercoated black and packaged with installation instructions and Grade 8 hardware. This driveshaft loop is designed to mount to the floor pan within six inches of the front universal joint, with the loop oriented up in the transmission tunnel. Installation requires that the user add four holes to the floor pan for the provided mounting bolts. Installation instructions are included. http://www.metcomotorsports.com/proddetail.asp?prod=MDL1600 How does it do with the seat bracket mounts does it hit the seats at all mounts
