A-body driveshaft loops #1706624
12/04/14 03:06 PM
12/04/14 03:06 PM
PENNSYLVANIA
CERTIFIABLE_HEMI Offline OP
PENNSYLVANIA
Are the A-body aluminum driveshaft safety loops still made that attach to the transmission crossmember, and if so who sells them? They were sold on e-bay at one time. Just can't remember who it was. Thanks!
Re: A-body driveshaft loops [Re: CERTIFIABLE_HEMI] #1706625
12/04/14 04:22 PM
12/04/14 04:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Aluminium ??? U S Cartool makes them in Steel < I would imagine something in alum would be almost as heavy as steel to have the same strength ???
On that note I can't say that I have ever seen an Alum one , is that even <insert racing body here> legal ?
Re: A-body driveshaft loops [Re: CERTIFIABLE_HEMI] #1706626
12/04/14 04:59 PM
12/04/14 04:59 PM
New York
DartS Offline
DartS  Offline
New York
Mancini sells the steel ones.
Re: A-body driveshaft loops [Re: JohnRR] #1706627
12/04/14 05:28 PM
12/04/14 05:28 PM
PENNSYLVANIA
PENNSYLVANIA
I have an aluminum one for a B-body and it is considerably lighter than steel. Just need one for the Pure Stock races, so I'm not concerned if it's NHRA legal.
Re: A-body driveshaft loops [Re: CERTIFIABLE_HEMI] #1706628
12/04/14 05:37 PM
12/04/14 05:37 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
I'm using one similar to this on my 69 Dart.
http://www.ebay.com/itm/Nice-Mopar-Dodge...744&vxp=mtr
1972 Road Runner
1988 Shelby CSX-T
Re: A-body driveshaft loops [Re: CERTIFIABLE_HEMI] #1706629
12/04/14 06:00 PM
12/04/14 06:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It may be considerably lighter than steel but it would be interesting to see what it , and the floor pan , looks like should the shaft do the unthinkable.
Where did you get the B body one ?
Re: A-body driveshaft loops [Re: JohnRR] #1706630
12/04/14 06:04 PM
12/04/14 06:04 PM
PENNSYLVANIA
PENNSYLVANIA
It was on a '68 Roadrunner that I bought years ago.
Re: A-body driveshaft loops [Re: CERTIFIABLE_HEMI] #1706631
12/05/14 12:37 AM
12/05/14 12:37 AM
Utah, USA
1964superstock Offline
Utah, USA
1967-1976 A-Body (Duster, etc)
Metco's one-piece driveshaft safety loop is custom-designed to fit the floor pan of the 1967-1976 MoPar A-Body. The ring is made from seamless DOM steel in an oversize dimension to accommodate lowered vehicles and aftermarket driveshafts. The flanges are laser-cut from heavy-duty steel and the assembly is precision-welded in a fixture. The finished loop is powdercoated black and packaged with installation instructions and Grade 8 hardware.
This driveshaft loop is designed to mount to the floor pan within six inches of the front universal joint, with the loop oriented up in the transmission tunnel. Installation requires that the user add four holes to the floor pan for the provided mounting bolts. Installation instructions are included.
http://www.metcomotorsports.com/proddetail.asp?prod=MDL1600
Re: A-body driveshaft loops [Re: 1964superstock] #1706632
12/05/14 01:24 AM
12/05/14 01:24 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
There was a guy on Ebay selling aluminium drive shaft loops for mopars....
Tony
70 AARCuda Vitamin C
Re: A-body driveshaft loops [Re: 70AARcuda] #1706633
12/05/14 01:40 AM
12/05/14 01:40 AM
BDW Offline
BDW  Offline
Re: A-body driveshaft loops [Re: CERTIFIABLE_HEMI] #1706634
12/05/14 02:24 AM
12/05/14 02:24 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
An Alum driveshaft safety loop IMO ranks right up there with an Alum roll bar. Can be done, I sure would not do it, and likely not legal anywhere. Save weight with an alum DS first if that is the objective, which would give an Alum safety loop a fighting chance.
Re: A-body driveshaft loops [Re: jcc] #1706635
12/05/14 02:37 AM
12/05/14 02:37 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Aluminum driveshaft is likely to reduce rotational inertia if the diameter or thickness isn't increased too much. Aluminum driveshaft loop should be low on the weight savings list of things to do.
Re: A-body driveshaft loops [Re: MuuMuu101] #1706636
12/05/14 02:00 PM
12/05/14 02:00 PM
PENNSYLVANIA
PENNSYLVANIA
Thanks for all the replies! Looks like I'm going to go with US CarTools loop.
Re: A-body driveshaft loops [Re: 1964superstock] #2414531
12/07/17 01:29 AM
12/07/17 01:29 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
How does it do with the seat bracket mounts does it hit the seats at all mounts
