Fuel line clamp tool.? #1706576
12/04/14 01:05 PM
12/04/14 01:05 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I bought the "concours" rubber fuel lines and clamps ( corbin?). What is the proper tool to clamp them?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Fuel line clamp tool.? [Re: JMCFAN] #1706577
12/04/14 01:10 PM
12/04/14 01:10 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Might not be 100% correct, but use a wire cutter (easy) and go one side to the other . . .
Re: Fuel line clamp tool.? [Re: JMCFAN] #1706578
12/04/14 01:14 PM
12/04/14 01:14 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Fuel line clamp tool.? [Re: JMCFAN] #1706579
12/04/14 01:25 PM
12/04/14 01:25 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
End cutters work good.
Re: Fuel line clamp tool.? [Re: 71birdJ68] #1706580
12/04/14 01:27 PM
12/04/14 01:27 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I bought the tool that Gary shows. Maybe I'm not using it correctly but I couldn't get the clamps to look like the original ones. They look pretty sloppy compared to what the original ones looked like.
The center piece moves around too much. If you could adjust the height and lock it there, I think it would do a better job.
Re: Fuel line clamp tool.? [Re: 71birdJ68] #1706581
12/04/14 01:31 PM
12/04/14 01:31 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
That was my first thought!
Re: Fuel line clamp tool.? [Re: 71birdJ68] #1706582
12/04/14 03:33 PM
12/04/14 03:33 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
I would use a file to remove and round off the cutting edges. This way you don't have to worry about nicking or weakening the clamp.
Re: Fuel line clamp tool.? [Re: Snoopy] #1706583
12/04/14 03:36 PM
12/04/14 03:36 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Good idea! Go buy a cheap pair at Harbor F....
Re: Fuel line clamp tool.? [Re: JMCFAN] #1706584
12/04/14 05:58 PM
12/04/14 05:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can get the correct tool I'm pretty sure at at cheap chinese junk central , or Vatozone , for about 10 bucks .
Re: Fuel line clamp tool.? [Re: JohnRR] #1706585
12/04/14 06:15 PM
12/04/14 06:15 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you use side cutters they will crimp them on, BUT, they will also allow the center piece of metal bend upwards forming a diamond shape which is incorrect in appearance. The proper pliers hold the top flat while the jaws pinch in the sides which also gives them a tighter grip.
Re: Fuel line clamp tool.? [Re: ScottSmith_Harms] #1706586
12/04/14 06:36 PM
12/04/14 06:36 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
OK....makes sense Scott.. I am searching...
Re: Fuel line clamp tool.? [Re: JMCFAN] #1706587
12/04/14 10:37 PM
12/04/14 10:37 PM
Cincinnati, Ohio
Cincinnati, Ohio
A KD 424 above can be bought at any auto parts store or wherever they sell KD tools.
Then this tool for the corbin clamps.
The one on the left is a old Blue Point tool I got from the Snap On guy 30 years ago. It's missing a spring but still works fine.
The one on the right I found in a antique store recently, it's missing a part and is worthless like it is. I think it was 3 bucks, I couldn't resist.
Here's the KD version.web page
Please don't install your corbin clamps with pliers or channel locks.
Re: Fuel line clamp tool.? [Re: Challenger 1] #1706588
12/04/14 11:16 PM
12/04/14 11:16 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
These clamps (often called "Keystone" clamps) crimped with side cutters (Top) and with the correct pliers (Bottom). The clamp on the bottom is how they should look once clamped.
Re: Fuel line clamp tool.? [Re: ScottSmith_Harms] #1706589
12/04/14 11:17 PM
12/04/14 11:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The pliers in action
Re: Fuel line clamp tool.? [Re: ScottSmith_Harms] #1706590
12/04/14 11:18 PM
12/04/14 11:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Pliers
Re: Fuel line clamp tool.? [Re: ScottSmith_Harms] #1706591
12/04/14 11:18 PM
12/04/14 11:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: Fuel line clamp tool.? [Re: ScottSmith_Harms] #1706592
12/04/14 11:24 PM
12/04/14 11:24 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Scott those pliers look different then the ones posted above... where can I find them..?. I have had no luck...
Re: Fuel line clamp tool.? [Re: Challenger 1] #1706593
12/04/14 11:25 PM
12/04/14 11:25 PM
Snoopy Offline
Snoopy  Offline
I think the OP is talking about the crimp style hose clamp rather than the Corbin spring style clamp.
Crimp style clamps and tools.
Re: Fuel line clamp tool.? [Re: Snoopy] #1706594
12/04/14 11:28 PM
12/04/14 11:28 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
NO..I am looking for the fuel line clamp tool...as Scott is showing above
Re: Fuel line clamp tool.? [Re: JMCFAN] #1706595
12/05/14 12:32 AM
12/05/14 12:32 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
These work and they're cheap.
