Re: Dual point distributor
[Re: sixpackman]
#1705981
12/02/14 05:24 PM
12/02/14 05:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Dual points increase the dwell time for all cylinders, they do not control one bank over the other.
Your miss may not be ignition related.
[Re: sixpackman]
#1705982
12/02/14 06:33 PM
12/02/14 06:33 PM
RapidRobert
misses at idle/part throttle/wot? Describe the miss, what parts/systems have been replaced/checked. When did it start, any changes that immediately preceding it missing? Some times on a toughie I go back to a basic compression test to make sure I ain't got a dead hole. If you ground each plug wire does it slow a bit? rotor radial gap/phasing OK?
