Dual point distributor #1705980
12/02/14 05:13 PM
12/02/14 05:13 PM
Michigan, USA
sixpackman Offline OP
Michigan, USA
Hello,
I have a 1970 Cuda 440-6 with a miss in the motor. Put a complete tune-up in it but can't locate the issue.
In the distributor does each set of points operate one bank of the motor? It seems like I'm getting twice the spark on the drives bank than the passenger? I have changed, checked, tuned, and replaced everything and nothing. I even used a dwell meter to tune the points. Any help would be GREATLY appreciated.
Re: Dual point distributor [Re: sixpackman] #1705981
12/02/14 05:24 PM
12/02/14 05:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Dual points increase the dwell time for all cylinders, they do not control one bank over the other.
Your miss may not be ignition related.
Don't be the exception.
Re: Dual point distributor [Re: sixpackman] #1705982
12/02/14 06:33 PM
12/02/14 06:33 PM
misses at idle/part throttle/wot? Describe the miss, what parts/systems have been replaced/checked. When did it start, any changes that immediately preceding it missing? Some times on a toughie I go back to a basic compression test to make sure I ain't got a dead hole. If you ground each plug wire does it slow a bit? rotor radial gap/phasing OK?
Re: Dual point distributor [Re: sixpackman] #1705983
12/03/14 07:57 PM
12/03/14 07:57 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Watch for frayed / broken litz wire conducting the ground current "around" the ball bearing breaker plate. Drive it very long that way, bearing balls get arc-welded.
Post a good pix w/ rotor removed.
Rick
Re: Dual point distributor [Re: Rick_Ehrenberg] #1705984
12/04/14 03:09 AM
12/04/14 03:09 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
is this a factory 8 lobe shaft dist? some aftermarket have 4 lobes one set of pts for 4 cyls, other for the other 4.
did you set dwell by blocking one set of points with a clean business card, set the un-blocked set, then reverse and set the other?
Check the leads within the dist for chafing and also the dist cap for arcing/cracks.
