Turbo vs SLR
#1705220
11/30/14 09:44 PM
11/30/14 09:44 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
Since turbos like load What would be a better Starting Line Ratio? rear gear 3.23 or 3.55 275 et pro tire on 10" rim Trans A-999 A-500 727 518 trying to decide which Trans/rear gear comb to run street cruiser/ weekend track car engine is .040 over 340, 9.64 compression ported edenbrock No cam yet Watching >>>>Dizuster<<< turbo kit post Was thinking about this While prepping the floor/ trans cross member for a 518 with trans shield. Only cause it needs the most clearance to fit. thanks Howard
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
Re: Turbo vs SLR
[Re: draginmopars]
#1705221
12/01/14 12:04 AM
12/01/14 12:04 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
If you are looking to make big power go with a 3.23 rear with either trans to get your slr down. Then tune with a convertor to get your power where it needs to be. Its easier to manage a looser convertor then a tight one on small tires.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Turbo vs SLR
[Re: draginmopars]
#1705224
12/01/14 01:05 PM
12/01/14 01:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since its a cruiser I would run the 518.. you get the OD with it(but loose the input and pump gears for the normal 727 input and pump gears... either rear gear should load the engine enough.. but the 3.23 would really drop the rpms in OD when cruising... figure out the rpm that you want to cross the line and use the best rear gear
Re: Turbo vs SLR
[Re: MR_P_BODY]
#1705225
12/01/14 11:14 PM
12/01/14 11:14 PM
draginmopars
smyrna,tn
thanks,for the replies,
We are wanting to build a dual purpose vehicle. cruise/track
mild turbo engine, easier on parts (?) VS radical stroker setting off car alarms every where to goes.
Howard
Re: Turbo vs SLR
[Re: draginmopars]
#1705226
12/02/14 03:58 PM
12/02/14 03:58 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yeah now a days boost is the way to go. no big lumpy bumpy cams, big cubic inches, stall and non-fun highway gears. When this engine goes, the next build will be boosted for sure.
Re: Turbo vs SLR
[Re: Mr.Yuck]
#1705227
12/02/14 04:04 PM
12/02/14 04:04 PM
1967dartgt
Hilltown Pa
Slr is for a race car and not a street crusier. Use what ever gears that will make you happy on the street. Maybe a 3.55 to get on boost easier when crusing.
Re: Turbo vs SLR
[Re: draginmopars]
#1705229
12/02/14 08:24 PM
12/02/14 08:24 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I don't know what this car weighs... but I have lots of broken 727, 8 3/4" pictures I could show you when I only had home ported iron heads, non-pro 275's, and a REAL small cam...
Eddy's, a good cam, and pro's are only going to make more power/be harder on the driveline.
Just based on that, I wouldn't bother even trying the 904. And I also would think REAL hard about putting a Dana in the car.
Just depends what kind of ET you're looking for though.
Re: Turbo vs SLR
[Re: dizuster]
#1705230
12/02/14 10:23 PM
12/02/14 10:23 PM
draginmopars
smyrna,tn
being dual purpose
on the topic of a dana
what about 4.10 dana gear running with A-518 (because that's the gear in the White Dart now. 1350 joints) have a 3.54 gear but would have to narrow a housing. don't want to change out the 4.10 vs 3.54
have a 518 (diesel) out of a pulling truck with good parts in it 5 pinion, hardened input shaft, billet drum, etc could swap into the A-518??????
would the 3.54 be a better ratio ? ET pros are 26" tall
I know very little about setting up a turbo application trying to learn.
Howard
Re: Turbo vs SLR
[Re: draginmopars]
#1705231
12/02/14 10:33 PM
12/02/14 10:33 PM
MR_P_BODY
being dual purpose
The valve body in a diesel trans is all wrong for a gas engine
Re: Turbo vs SLR
[Re: draginmopars]
#1705232
12/02/14 10:35 PM
12/02/14 10:35 PM
draginmopars
smyrna,tn
what about 1350 vs 1410 would have to buy another set of 1350
have a complete set 1410 yokes could use ?
Howard
Re: Turbo vs SLR
[Re: MR_P_BODY]
#1705233
12/02/14 10:39 PM
12/02/14 10:39 PM
draginmopars
smyrna,tn
being dual purpose
Mike was only going to rob the good parts> pinion gears, drums, input shaft since the case is cracked anyway, where it bolts to the adapter plate on the diesel use the valve body and governor in the (Car)trans
Howard
Re: Turbo vs SLR
[Re: draginmopars]
#1705234
12/02/14 10:44 PM
12/02/14 10:44 PM
MR_P_BODY
being dual purpose
Is the input shaft and pump for a 727 conv
Re: Turbo vs SLR
[Re: MR_P_BODY]
#1705235
12/02/14 10:51 PM
12/02/14 10:51 PM
draginmopars
smyrna,tn
yes I have a 3500 converter thought about using
has anti ballooning plates
Howard
Re: Turbo vs SLR
[Re: draginmopars]
#1705236
12/03/14 12:35 AM
12/03/14 12:35 AM
1967dartgt
Hilltown Pa
Pro is 28 inches tall. Comes in one size 275/60/15 or 28/10.
