Turbo vs SLR #1705220
11/30/14 09:44 PM
11/30/14 09:44 PM
smyrna,tn
draginmopars Offline OP
smyrna,tn
Since turbos like load
What would be a better Starting Line Ratio?
rear gear 3.23 or 3.55
275 et pro tire on 10" rim
Trans
A-999
A-500
727
518
trying to decide which Trans/rear gear comb to run
street cruiser/ weekend track car
engine is .040 over 340,
9.64 compression
ported edenbrock
No cam yet
Watching >>>>Dizuster<<< turbo kit post
Was thinking about this
While
prepping the floor/ trans cross member for a 518 with trans shield.
Only cause it needs the most clearance to fit.
thanks
Howard
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Turbo vs SLR [Re: draginmopars] #1705221
12/01/14 12:04 AM
12/01/14 12:04 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
If you are looking to make big power go with a 3.23 rear with either trans to get your slr down. Then tune with a convertor to get your power where it needs to be. Its easier to manage a looser convertor then a tight one on small tires.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Turbo vs SLR *DELETED* [Re: 1967dartgt] #1705222
12/01/14 12:35 PM
12/01/14 12:35 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Post deleted by TheOtherDodge
Re: Turbo vs SLR [Re: TheOtherDodge] #1705223
12/01/14 01:01 PM
12/01/14 01:01 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my buddy runs low 8's at 170 w/ 3.55 gear and a turbo 400 trans... that said I'd think it al depends on your converter and what you are looking to do with the car.
Coming soon!!!!
Re: Turbo vs SLR [Re: draginmopars] #1705224
12/01/14 01:05 PM
12/01/14 01:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since its a cruiser I would run the 518.. you get the
OD with it(but loose the input and pump gears for the
normal 727 input and pump gears... either rear gear
should load the engine enough.. but the 3.23 would
really drop the rpms in OD when cruising... figure
out the rpm that you want to cross the line and use
the best rear gear
Re: Turbo vs SLR [Re: MR_P_BODY] #1705225
12/01/14 11:14 PM
12/01/14 11:14 PM
smyrna,tn
smyrna,tn
thanks,for the replies,
We are wanting to build a dual purpose vehicle.
cruise/track
mild turbo engine, easier on parts (?)
VS radical stroker
setting off car alarms every where to goes.
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Turbo vs SLR [Re: draginmopars] #1705226
12/02/14 03:58 PM
12/02/14 03:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
cruise/track
VS radical stroker
yeah now a days boost is the way to go. no big lumpy bumpy cams, big cubic inches, stall and non-fun highway gears. When this engine goes, the next build will be boosted for sure.
Re: Turbo vs SLR [Re: Mr.Yuck] #1705227
12/02/14 04:04 PM
12/02/14 04:04 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Slr is for a race car and not a street crusier. Use what ever gears that will make you happy on the street. Maybe a 3.55 to get on boost easier when crusing.
Re: Turbo vs SLR [Re: 1967dartgt] #1705228
12/02/14 06:06 PM
12/02/14 06:06 PM
smyrna,tn
smyrna,tn
Driving the Race car to the track..
this car isn't a daily driver, just a "Fun" car
Need the SLR when we get there
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Turbo vs SLR [Re: draginmopars] #1705229
12/02/14 08:24 PM
12/02/14 08:24 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I don't know what this car weighs... but I have lots of broken 727, 8 3/4" pictures I could show you when I only had home ported iron heads, non-pro 275's, and a REAL small cam...
Eddy's, a good cam, and pro's are only going to make more power/be harder on the driveline.
Just based on that, I wouldn't bother even trying the 904. And I also would think REAL hard about putting a Dana in the car.
Just depends what kind of ET you're looking for though.
Re: Turbo vs SLR [Re: dizuster] #1705230
12/02/14 10:23 PM
12/02/14 10:23 PM
smyrna,tn
smyrna,tn
being dual purpose
on the topic of a dana
what about 4.10 dana gear running with A-518
(because that's the gear in the White Dart now.
1350 joints)
have a 3.54 gear but would have to narrow a housing.
don't want to change out the 4.10 vs 3.54
have a 518 (diesel) out of a pulling truck with good parts in it
5 pinion, hardened input shaft, billet drum, etc
could swap into the A-518??????
would the 3.54 be a better ratio ?
ET pros are 26" tall
I know very little about setting up a turbo application
trying to learn.
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Turbo vs SLR [Re: draginmopars] #1705231
12/02/14 10:33 PM
12/02/14 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
being dual purpose
1350 joints)
trying to learn.
The valve body in a diesel trans is all wrong for
a gas engine
Re: Turbo vs SLR [Re: draginmopars] #1705232
12/02/14 10:35 PM
12/02/14 10:35 PM
smyrna,tn
smyrna,tn
what about 1350 vs 1410
would have to buy another set of 1350
have a complete set 1410 yokes could use ?
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Turbo vs SLR [Re: MR_P_BODY] #1705233
12/02/14 10:39 PM
12/02/14 10:39 PM
smyrna,tn
smyrna,tn
being dual purpose
1350 joints)
trying to learn.
a gas engine
Mike
was only going to rob the good parts> pinion gears, drums, input shaft since the case is cracked anyway, where it bolts to the adapter plate on the diesel
use the valve body and governor in the (Car)trans
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Turbo vs SLR [Re: draginmopars] #1705234
12/02/14 10:44 PM
12/02/14 10:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
being dual purpose
1350 joints)
trying to learn.
a gas engine
Mike
Is the input shaft and pump for a 727 conv
Re: Turbo vs SLR [Re: MR_P_BODY] #1705235
12/02/14 10:51 PM
12/02/14 10:51 PM
smyrna,tn
smyrna,tn
yes
I have a 3500 converter
thought about using
has anti ballooning plates
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Turbo vs SLR [Re: draginmopars] #1705236
12/03/14 12:35 AM
12/03/14 12:35 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Pro is 28 inches tall. Comes in one size 275/60/15 or 28/10.
Re: Turbo vs SLR [Re: 1967dartgt] #1705237
12/03/14 02:08 AM
12/03/14 02:08 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
You'll be well out of 3rd gear before the end of the track with the 4.10. I wouldn't want to run that much torque through the 518 OD unit. Not to mention they are not real effecient.
3.55 Dana would be your best option with the good Trans parts in a 727.
3.55 gears are all over the place. If you're on a budget get a used one and swap it in. That's what mine has in it.
