building a 360 what to expect from this combo? #1705159
11/30/14 07:11 PM
11/30/14 07:11 PM
mesa arizona
moturbopar Offline OP
mesa arizona
73 360 block, 30 over
probe forged pistons 9.8 to 1 = 615 grams
0 deck
9.8 to 1
scat rods, 595 grams
stock crank, cut .010 under
Magnum eq heads, 2.02 valve 1.62 exhaust, ported
intake flows 270 at .550 exst flows 194 at .550
Cam is a Lunati voodoo 264/272 solid lifter flat tappet
Specs are dur 235 in at .050 243 ext at .050 110 lobe seperation set on a 106 ic. .545 lift int .566 ext with 1.6 roller rockers.
performer rpm air gap
holley 750 dbl pump
1 5/8 headers, 3" dual exhaust into x pipe.
I would like to see 400+ hp and torque,
so what do you guys think this will idle like? being solid lifter and fairly short duration, i think it wont be too radical, do you think this cam will work with power brakes and maybe A/C? Anybody here used a voodoo solic cam befor?
Re: building a 360 what to expect from this combo? [Re: moturbopar] #1705160
11/30/14 07:27 PM
11/30/14 07:27 PM
You will see that
Re: building a 360 what to expect from this combo? [Re: RapidRobert] #1705161
11/30/14 09:24 PM
11/30/14 09:24 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You will see that
I disagree.
Mid 300s at the wheels.
Mopar Muscle just ran this:
he 422ci stroker combination in Steve Moyer's '71 Plymouth Duster is the top LA-Series small-block in our competition. With 343 wheel horsepower on tap, it is a stout street combo, based on a stock 340 block and a 4.00-inch stroke crank. The modest compression ratio of 9.5:1 generated by Diamond dished pistons ensures easy pump gas performance, the gasoline being fed via a Quick Fuel 750 carb perched upon an Edelbrock AirGap intake manifold. The cylinder heads are Indy T/A's, a variation of the Edelbrock casting with offset intake rocker arms for a larger port cross-section. Mopar Performance supplied the cam, featuring 272 degrees duration at .050-inch and .533-inch lift.
RPM: HP:
4,200 222
4,300 253
4,400 275
4,500 292
4,600 308
4,700 321
4,800 331
4,900 337
5,000 343
Max Power 343
That engine had similar displacement, similar heads, one step smaller cam, and an extra 60 cubic inches.
It didn't even come close to 400 hp at the wheels.
Will his engine make 400 hp at the crank? Sure! Will it be a fun street car? You bet. Will it make 400 rwhp? Not without nitrous.
If you're building to hit a specific hp number I think you're looking at things the wrong way.
Build the engine to run how you want it to run and let the numbers fall where they fall.
- Stu Harmon
Re: building a 360 what to expect from this combo? [Re: RapidRobert] #1705162
11/30/14 09:27 PM
11/30/14 09:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: building a 360 what to expect from this combo? [Re: feets] #1705163
11/30/14 09:29 PM
11/30/14 09:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I disagree.
Missed the heads did you?
You're looking at LA based heads, he's running Magnum based.
Re: building a 360 what to expect from this combo? [Re: Supercuda] #1705164
11/30/14 09:35 PM
11/30/14 09:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I disagree.
hmmm....
His Maggies are not going to run 60 hp more than the Indy heads with 60 less inches and a similar bottom end.
Sorry, it's not going to hit 400 rwhp.
- Stu Harmon
Re: building a 360 what to expect from this combo? [Re: Supercuda] #1705165
11/30/14 09:38 PM
11/30/14 09:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Kinda overkill for 400hp.
http://www.hotrod.com/how-to/engine/hrdp-0804-small-block-mopar-engine/
Read that again:
Mopar Magnum 360
SuperFlow 901 engine dyno
Now, take out 20% for drivetrain loss.
448 crank hp?
OOPS!!! There went 90 hp.
It's down to 350 at the wheels.
Try this one on for size:
A big-inch Gen II Hemi muscle motor in an iconic muscle car is a hard combination to beat. This 528-cube Hemi is wall-to-wall motor under the hood, with Indy cylinder heads providing the flow, and a Ray Barton single-plane manifold fed by a 950-cfm Demon carb delivering the atmosphere. The pump delivers a mild street-friendly compression ratio of 10:1—mild enough to fill at the corner station. The big Hemi exhales through TTI headers flowing into a 3-inch exhaust system featuring Flowmaster 40 mufflers.
RPM: HP:
5,000 337
5,100 363
5,200 376
5,300 383
5,400 392
5,500 401
5,600 406
5,700 404
5,800 404
5,900 405
Max Power 406
- Stu Harmon
Re: building a 360 what to expect from this combo? [Re: feets] #1705166
11/30/14 09:40 PM
11/30/14 09:40 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Your the only one mentioning rear wheel HP, the OP did not.
Re: building a 360 what to expect from this combo? [Re: nomore65BelvJim] #1705167
11/30/14 09:42 PM
11/30/14 09:42 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
oops.
I still stand by what I said earlier.
Build the engine to run how you want it to run and let the numbers fall wherever they fall.
- Stu Harmon
Re: building a 360 what to expect from this combo? [Re: moturbopar] #1705168
11/30/14 10:56 PM
11/30/14 10:56 PM
ky.
K
kenworth_goose Offline
K
ky.
I built a 360 for a 68 dart a while back and it was follows;
360 standard bore block
kb 10to 1's on 273 rods
windage tray
hi volume oil pump
508 purple shaft
stock 78 heads, new valve job
adjustable valve train, set at zero lash
edlebrock single plane intake
holley 750 double pumper with huge jets
mopar electronic ignition
hooker hedders
had a rebuilt 904 with a stock convertor, The stall hadn't been ordered in time
has a shift kit in the trans
3.91's
and full exhaust
The full bodied car ran 12.40's with zero traction! Car had full interior, heater box, everything that it left the factory with. Engine was well over 425 hp. I sold the car before I could get the stall in it and a set of slicks on it and see how deep into the 11's I could go. want to see it run and do a crazy burnout? Go to youtube and look up kenworthgoose. The burnout was in Heath If I remember right at the Chrysler dealership in 2002, I think.
Re: building a 360 what to expect from this combo? [Re: moturbopar] #1705169
11/30/14 10:58 PM
11/30/14 10:58 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
"Should" run mid 11's or better in an A body(3200lbs ish) with reasonable gears and converter. 400hp is a good guess. If a magazine built it add 60-100hp or so.
Re: building a 360 what to expect from this combo? [Re: goldmember] #1705170
12/01/14 12:47 AM
12/01/14 12:47 AM
Central NC
gch Online content
gch  Online Content
Central NC
RPM: HP:
4,200 222
4,300 253
4,400 275
4,500 292
4,600 308
4,700 321
4,800 331
4,900 337
5,000 343
Max Power 343
Is it just me or would that engine not make peak power higher than 5000rpm?Maybe the cam spec of 272* @ .050 should have been gross duration.
Re: building a 360 what to expect from this combo? [Re: gch] #1705171
12/01/14 01:08 AM
12/01/14 01:08 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
no the cam spec is correct.
that is one big hydraulic cam..
Part number is P4529317
*P4529317 320/320 272/272 104 108 .533/.533 P5249847 3800-6400
Tony
70 AARCuda Vitamin C
Re: building a 360 what to expect from this combo? [Re: gch] #1705172
12/01/14 01:56 AM
12/01/14 01:56 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
RPM: HP:
4,200 222
4,300 253
4,400 275
4,500 292
4,600 308
4,700 321
4,800 331
4,900 337
5,000 343
Max Power 343
Looks like to much cam and a out dated one at that for a anemic 9.5 cr. Plus the carb is small.
Re: building a 360 what to expect from this combo? [Re: ademon] #1705173
12/01/14 03:06 AM
12/01/14 03:06 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The OP's deal with a good tune up will make 400/400 easily. I wouldn't be surprised if it made 430 or more HP/TQ.
Re: building a 360 what to expect from this combo? [Re: RobX4406] #1705174
12/01/14 01:30 PM
12/01/14 01:30 PM
mesa arizona
mesa arizona
Cool, Thanks for the replies! I dont expect 400 wheel hp, all though it would be cool! 400 at the crank is what i was looking for. So do you guys think this cam will produce vacuum for power brakes?
Re: building a 360 what to expect from this combo? [Re: moturbopar] #1705175
12/01/14 01:36 PM
12/01/14 01:36 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I built a couple of 360 lately and your combo looks great
Lots of fun and great moments ahead!
My guess is 450hp at the crank and 400lbs tq....
I like your carb choice too....
Dan
Re: building a 360 what to expect from this combo? [Re: moturbopar] #1705176
12/01/14 05:31 PM
12/01/14 05:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Sounds like a nice motor to me, the only thing I would change is the EX lobe, use the same one as the intake, the magnum EQ flows real good on the exhaust and does not need the chevy cam.
Re: building a 360 what to expect from this combo? [Re: HotRodDave] #1705177
12/02/14 09:33 PM
12/02/14 09:33 PM
mesa arizona
mesa arizona
I planned on having a custom ground cam made, but lunati reccomended this one. The engine is going into a 84 short bed dodge truck, not a light A body, the truck is surprisingly light though after some weight reduction. Weighs less than my old 67 b body! Has 410 gears, and a 10" converter.
Re: building a 360 what to expect from this combo? [Re: moturbopar] #1705178
12/03/14 12:52 AM
12/03/14 12:52 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
That cam is ok for a mild street truck.
