Front end clunking 03 liberty #1704605
11/29/14 07:55 PM
11/29/14 07:55 PM
Staten Island, NY
RO23dave Offline OP
RO23dave  Offline OP
Staten Island, NY
"03 liberty 114,000 miles bought from dealer w/79,000 miles, noise in front was there but not so pronounced. Checked ball joints lowers were tight, uppers shot, replaced upper control arms w/ball joints, just replaced sway bar links. Noise still clunking, in fact sounds like it's a bouncing clunk. Struts attached to a fork bolted to lower control arm thru a huge bushing. Anyone have this problem might steer me in right direction. Bushing worn & cross bolt sloppy? Strut assembly shot? Don't know when strut was or ever changed. I know the upper control arm (wishbone) on rear end ball joint there is bad but noise up front is low. Any suggestions where to start or how to diagnose greatly appreciated. Thanks. Dave. Ss/ea. #1355.
Re: Front end clunking 03 liberty [Re: RO23dave] #1704606
11/29/14 10:50 PM
11/29/14 10:50 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Lower control arm bushings.
Earning every penny of that moderator paycheck.
DBAP
Re: Front end clunking 03 liberty [Re: RO23dave] #1704607
11/29/14 11:57 PM
11/29/14 11:57 PM
NY NY
3
340duster340 Offline
NY NY
what do the sway bar end links look like?
Re: Front end clunking 03 liberty [Re: RO23dave] #1704608
11/30/14 02:01 AM
11/30/14 02:01 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Check the sway bar to frame bushings.
Re: Front end clunking 03 liberty [Re: NITROUSN] #1704609
12/01/14 02:40 AM
12/01/14 02:40 AM
Ohio
Todd Offline
Todd  Offline
Ohio
This
