Simple question about oil pan gaskets #170387
12/18/08 10:08 PM
12/18/08 10:08 PM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
I need to replace the oil pan gasket on my 440. I picked up the nice "impossible to rip" version from Milodon. Do you install these dry or with RTV? The package doesn't say and neither does their web site.
Re: Simple question about oil pan gaskets [Re: Chilort] #170388
12/18/08 10:28 PM
12/18/08 10:28 PM
Chesapeake, Va
4aThrill Offline
4aThrill  Offline
Chesapeake, Va
a thin coat of RTV on either side of the gasket, thats what I did with mine, the tear proof gaskets work great no problems yet just do the normal stuff like any other gasket. clean the surfaces check the pan for uneven spots fix em and so on
Re: Simple question about oil pan gaskets [Re: 4aThrill] #170389
12/18/08 11:15 PM
12/18/08 11:15 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I just put 'em on dry.
I haven't filled it up with oil yet.
I'd cleaned all surfaces really well and had already straightened out the pan too ....
But, when I was tightening down the pan to the 200inlbs as in the book, the pan bent right back to how it had been before, if not worse.
I'll likely pull it all back apart tomorrow, use some rtv, and go a little looser on the pan bolts.
Any suggestions for torque?
I could never be a hooker. Something about laying on my back and getting up and down a bunch gives me a huge headache.
Re: Simple question about oil pan gaskets [Re: Chilort] #170390
12/18/08 11:20 PM
12/18/08 11:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Using RTV and new gaskets is like wearing a elt and suspenders.Ive been a pro wrench for 40 years and never use RTV with gaskets.Its not needed and if you have to use it something is wrong.My pan gaskets are 10 years old the cheap MP ones.Still no leaks at 80 PSI oil pressure.Rocky
Chrysler Firepower
Re: Simple question about oil pan gaskets [Re: therocks] #170391
12/19/08 04:22 AM
12/19/08 04:22 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I guess we'll see what dry does. Hopefully 200inlbs did't bend the pan too much.
