Sure Grip, locker, or spool? #1703278
11/25/14 10:31 PM
11/25/14 10:31 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Hey fellas. I have an 89 Ram 50 mini truck with a small block, narrowed 8-3/4" rear, 4-link and 18.5" wide Hoosiers under it. I have a 489 case with a 3:23 open diff sitting here. I want to replace it with either a Suregrip a locker or a spool and 4:10 gears.
The truck will be both street driven and taken to the track quite a bit. So I think a spool might be a bit too much. Then again, maybe not. Many any have experience with a spool or a locker in a street/strip vehicle?
Recommendations?
Laine
Re: Sure Grip, locker, or spool? [Re: Lmopar69] #1703279
11/25/14 10:40 PM
11/25/14 10:40 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I personally can't stand spools or lockers on the street. If it is strip only then a spool may make sense depending on how hard it is to get traction.
Re: Sure Grip, locker, or spool? [Re: HotRodDave] #1703280
11/26/14 01:18 AM
11/26/14 01:18 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A spool is a terrible rear for any street use. It hops on corners and is hard on the rear end. Both the vehicles and the drivers.
Re: Sure Grip, locker, or spool? [Re: stumpy] #1703281
11/26/14 01:32 AM
11/26/14 01:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been running a Detroit Locker in my 63 for years on the street. I take it to the track and race once or twice a year right now as thats all my budget will let me. Myself I love the locker as it works great for me. Sure it makes a little noise sometimes but nothing that even notice most of the time. To me its a great street/strip choice. Many guys do run a spool on the street but I drive my 63 alot and take alot of the long beltway ramps and dont want to be fighting a spool like that. If it was race only then of course I would run a spool. Ron
Re: Sure Grip, locker, or spool? [Re: Lmopar69] #1703282
11/26/14 01:41 AM
11/26/14 01:41 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Spool on the street?
VERY bad idea, ANY amount of moisture on the street and it's like being on glare ice. Rounding corners drags a tire and can break an axle, and not always when you are turning a corner, it can stress and break when least expected.
Nodular/Yukon (Tru-Track) 8.75 with a Sure Grip. Plenty for most any street strip car unless it's a big power/heavy car on slicks. Brand new drop in will run about $1250.00
Detroit Locker? Strongest of the 8.75's but they are noisy. I run one in my 71 Demon and am going back to a Nodular 8.75 Sure Grip, I just don't like the racket when cruising and probably don't need the extra strength on any tire that's streetable. These run a hundred bucks or so more than the Nodular/Yukon Tru-Track unit.
For a bit more $ you can buy a custom built Dana 60 from Cass and be done with it. In your case that would be my move.
Re: Sure Grip, locker, or spool? [Re: ScottSmith_Harms] #1703283
11/26/14 01:55 AM
11/26/14 01:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nodular/Yukon 8.75 with a Sure Grip. Plenty for most any street strip car unless it's a big power/heavy car on slicks. Brand new drop in will run about $1250.00
Detroit Locker? Strongest of the 8.75's but they are noisy. I run one in my 71 Demon and am going back to a Nodular 8.75 Sure Grip, I just don't like the racket when cruising and probably don't need the extra strength on any tire that's streetable. These run a hundred bucks or so more than the Nodular/Yukon unit.
Scott I am curious as you say you get a ratchet sound when cruising out of your locker ? I can say the only noise I hear is when it thumps a little sometimes when it locks back up but I dont hear any noises when just cruising along as my noise is just after turns and it locks the one wheel back up and once in a while I can actually feel a small bump when it locks back in. Course I am so used to it I dont even notice that much anymore but I have not noticed any racthet type of noise. Ron
Re: Sure Grip, locker, or spool? [Re: 383man] #1703284
11/26/14 02:00 AM
11/26/14 02:00 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No, I don't get the ratcheting noise on the street (but we do in our race car on the road course rounding corners) we plan to change it for a non locker, it's not a good road course rear. What I get is a weird harmonic reverberation noise, sort of a "rumm rumm rumm" sound (maybe it's drunk LOL!), all else has been checked, drive shaft and u-joints are new and right, etc. it's definitely the rear and all looks healthy inside (it's a nearly new unit).
Re: Sure Grip, locker, or spool? [Re: ScottSmith_Harms] #1703285
11/26/14 08:12 AM
11/26/14 08:12 AM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I run a spool on the street in my Satellite with drag radials. I don't have any issues but then again I dont drive it down the interstate or drive it in the rain. I didn't build it to do that. I do drive it to cruise ins ect.... I wouldn't try a spool on the street with out upgraded axles though....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Sure Grip, locker, or spool? [Re: QTR MILR] #1703286
11/26/14 08:32 AM
11/26/14 08:32 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
With that much tire I wouldn't be scared of a spool either. It's not like the truck will be a great rain/snow/road course vehicle anyway. Good axles are a must.
Re: Sure Grip, locker, or spool? [Re: 383man] #1703287
11/26/14 10:19 AM
11/26/14 10:19 AM
Minnesota
DLewis Offline
DLewis  Offline
Minnesota
On the street the locker doesn't bother me at all in a vehicle that's built to be loud and maybe a little clumsy in tight turns. The only time I really notice it is when parking or maneuvering in tight places, but prefer the ratchet sound to tires hopping and dragging with a spool.
Re: Sure Grip, locker, or spool? [Re: DLewis] #1703288
11/26/14 11:59 AM
11/26/14 11:59 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
i run a spool on a 4 wheel drive jeep with 35 inch tires .no problems on the street
Re: Sure Grip, locker, or spool? [Re: slantzilla] #1703289
11/26/14 12:08 PM
11/26/14 12:08 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Axles are Dutchman custom made for the narrowed 8-3/4 rear. Should be no problem there. A locker has been my primary thought. But since I've never been in a vehicle that has one, I don't know how they act on the street.
Odds are this one won't be driven in the rain, snow, ice... Ever. Unless I get caught in it sometime on the way home.
I have a 4:10 geared sure grip center section in my challenger currently (not on the road right now). But if memory serves,the sure grip unit was getting a bit soft and will need rebuilt.
My concern is that if this thing launches HARD, which it should, and the tires bite hard, which they should, that my old SG unit could slip and cause a nasty unwanted turn.
Thoughts?
Laine.
Re: Sure Grip, locker, or spool? [Re: ScottSmith_Harms] #1703290
11/26/14 12:15 PM
11/26/14 12:15 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
While a spool does take a little extra care, it is nowhere like driving on glare ice.
I would almost vote a locker more dangerous, because a locker turns into a spool when you apply power. So you go into a corner with an open diff and when you accelerate it locks up like a spool...that can get nasty in the wrong hands. Its also really fun to do it on purpose lol.
My jeep is locked front and rear, in the wet all it takes is a blip of the throttle to throw it sideways in a turn because it engages the locker. Its the only way to have sideways fun with a 250HP I6 and 35" tires, sure as heck won't do that on dry pavement lol.
My Barracuda has a spool and its a 100% low eleven second street car. Rain does require caution but I don't feel the spool is anymore dangerous than the locker in my jeep.
68 Barracuda Formula S 340
Re: Sure Grip, locker, or spool? [Re: Lmopar69] #1703291
11/26/14 12:15 PM
11/26/14 12:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thoughts?
Laine.
Save any guessing and get a Dana 60
Re: Sure Grip, locker, or spool? [Re: ScottSmith_Harms] #1703292
11/26/14 12:34 PM
11/26/14 12:34 PM
Eaton tru-trac....
Re: Sure Grip, locker, or spool? #1703293
11/26/14 02:46 PM
11/26/14 02:46 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
for that vehicle a spool.
Re: Sure Grip, locker, or spool? [Re: 1969ronnie] #1703294
11/26/14 10:09 PM
11/26/14 10:09 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That truck is like a Pro-Street unit and to me that means a 35 spline spool and axles from Doctordiff
I've been running spools on the street for 20 years and NEVER had an issue, except for the time I drove it to thanksgiving dinner about ten years ago when it snowed on the way home When you drive a spool on the street you just have to make sure it's pointed straight when you drop the hammer
Gus
64 Plymouth Savoy
Dana 60
