So I got my windshield out of the 37, I need tips #1703144
11/25/14 02:04 AM
11/25/14 02:04 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
I'm assuming I'm going to have to drill out all these screws that hold it together, any tips?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: So I got my windshield out of the 37, I need tips [Re: AZ_A12_BEE] #1703145
11/25/14 02:05 AM
11/25/14 02:05 AM
Dreaming of the 808
Dreaming of the 808
These ones too
Re: So I got my windshield out of the 37, I need tips [Re: AZ_A12_BEE] #1703146
11/25/14 02:06 AM
11/25/14 02:06 AM
Dreaming of the 808
Dreaming of the 808
The whole windshield
Re: So I got my windshield out of the 37, I need tips [Re: AZ_A12_BEE] #1703147
11/25/14 11:45 AM
11/25/14 11:45 AM
Lon207 Offline
Lon207  Offline
I just removed the windshield frame from my 47 truck. I just took a 1/4-20 nut, positioned it over the head of the screw, filled the nut with weld and all of them came out. I was able to put a wrench on the nut and remove them. I guess the heat doesn't hurt either.
Good luck!!
Re: So I got my windshield out of the 37, I need tips [Re: Lon207] #1703148
11/25/14 10:59 PM
11/25/14 10:59 PM
moparx Offline
moparx  Offline
what i did on my [really] rusty cowl vent screws,which were smaller than those holding your windsheild frame together, was to heat up the head to almost turning a very dull red, then place a birthday candle on the screw for about 10 seconds or so. the wax melted down around the head into the threads, and the screws came right out with very little effort. just make sure you watch your fingers as the candles get short kinda fast. also, make sure the screwdriver you use is the biggest, best fitting one you have that fits the slot so you don't cam out the slot, causing you to revert to "plan b".
Re: So I got my windshield out of the 37, I need tips [Re: moparx] #1703149
11/27/14 08:08 PM
11/27/14 08:08 PM
Dreaming of the 808
Dreaming of the 808
I got all but 2 out using a combination of PB Blaster, heat and a impact driver
Re: So I got my windshield out of the 37, I need tips [Re: AZ_A12_BEE] #1703150
11/28/14 01:02 PM
11/28/14 01:02 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
If the 2 remaining are near others you got out, clean the open holes and screws and reinstall tight. This will help relieve pressure on the stuck ones...
