So I got my windshield out of the 37, I need tips
#1703144
11/25/14 02:04 AM
11/25/14 02:04 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
I'm assuming I'm going to have to drill out all these screws that hold it together, any tips?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: So I got my windshield out of the 37, I need tips
[Re: Lon207]
#1703148
11/25/14 10:59 PM
11/25/14 10:59 PM
Posts: 19,492 north of coder
moparx
what i did on my [really] rusty cowl vent screws,which were smaller than those holding your windsheild frame together, was to heat up the head to almost turning a very dull red, then place a birthday candle on the screw for about 10 seconds or so. the wax melted down around the head into the threads, and the screws came right out with very little effort. just make sure you watch your fingers as the candles get short kinda fast. also, make sure the screwdriver you use is the biggest, best fitting one you have that fits the slot so you don't cam out the slot, causing you to revert to "plan b".
[Re: moparx]
#1703149
11/27/14 08:08 PM
11/27/14 08:08 PM
AZ_A12_BEE
Dreaming of the 808
I got all but 2 out using a combination of PB Blaster, heat and a impact driver
37 Plymouth PU
