'69 B-body drip rail moulding tool??? #1703087
11/24/14 11:43 PM
11/24/14 11:43 PM
Oologah, Oklahoma
Big Squeeze Offline OP
Oologah, Oklahoma
Does anyone make a tool to install/crimp new drip rail mouldings onto a '69 B-body? This car has a new vinyl top so it's a PIA to get them on....
If you can't handle the truth, you're living a lie.......
Re: '69 B-body drip rail moulding tool??? [Re: Big Squeeze] #1703088
11/25/14 01:00 AM
11/25/14 01:00 AM
Sunny San Diego
1sprinter Offline
1sprinter  Offline
Sunny San Diego
I've seen plastic removal tools all over but none for installation. I make sure my upholsterer goes thin when it overlaps the drip edge then set the top trim edge in and tap downward with a rubber mallet.
Re: '69 B-body drip rail moulding tool??? [Re: Big Squeeze] #1703089
11/25/14 01:01 AM
11/25/14 01:01 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
is the drip rail trim you are using for a vinyl roof car?
i know for sure on 71's there are 2 different drip rail trims
vinyl or no vinyl.. it might be the same thing for 69's also
its just something to research that could help you out some.
Re: '69 B-body drip rail moulding tool??? [Re: flypaper] #1703090
11/25/14 02:05 AM
11/25/14 02:05 AM
Oologah, Oklahoma
Oologah, Oklahoma
I've put them on cars without a top with a rubber hammer and it's not a problem, but with the top it's ridiculous....as far as I know there is only one drip rail moulding available for these cars???
Re: '69 B-body drip rail moulding tool??? [Re: flypaper] #1703091
11/25/14 10:14 AM
11/25/14 10:14 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
There are two different mouldings in 69. If you are trying to put the non vinyl top trim over a vinyl top, not going to happen.
Some other tips. Only leave the top about 1/2 way down the face of the drip rail. Don't bond the top to the face. This gives the top some flexibility when snapping on the trim plus with time it will be less likely to shrink in the gutter line and crack. So I have been told.
The only tool I use is my hands. I don't know of anything else that works well, on or off.
Hope this helps.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: '69 B-body drip rail moulding tool??? [Re: Big Squeeze] #1703092
11/25/14 11:48 AM
11/25/14 11:48 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
To the best of my knowledge, that trim does not "crimp" into place. You tilt the top over the drip rail then twist it down and it kinda snaps into place - hopefully not taking too much paint with it !!! On a vinyl top it would just have to stretch a little more but being stainless, its gonna fight you all the way.
Re: '69 B-body drip rail moulding tool??? [Re: Stanton] #1703093
11/25/14 12:31 PM
11/25/14 12:31 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
There is for sure two different drip rail trim on these cars. One for vinyl top and one without vinyl top. Like already said you can't use trim that is not vinyl top trim. However the repop trim only comes in one size that can be used on both.
I just installed some of the repop on a vinyl top car for a customer and it went on easy. The repop stainless is way less thick (made cheaper) than original so it is easier to install.
Here is a picture of how I trim the top so the stainless will snap on and still hold the top edge of the vinyl.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: '69 B-body drip rail moulding tool??? [Re: Big D A12] #1703094
11/25/14 12:42 PM
11/25/14 12:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Hope this helps.
...I only use my thumbs and palm of my hand to remove or install drip rail molding
Re: '69 B-body drip rail moulding tool??? [Re: MOPARMIKE69] #1703095
11/25/14 02:53 PM
11/25/14 02:53 PM
Oologah, Oklahoma
Oologah, Oklahoma
That's exactly how I've trimmed the top on this car and it's still fighting me....when I roll it down and try to snap it, it's as if the trim has been stretched/bent out of shape and will no longer "snap" into place...so I'm having to crimp it after it's on so it'll hold itself in place...was hoping there was a trick or I was missing something to make the other side easier...
Re: '69 B-body drip rail moulding tool??? [Re: Big D A12] #1703096
11/25/14 08:15 PM
11/25/14 08:15 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i wasn't 100% sure on 69's, but
just by reading his problem it
sounded like he was using the wrong part to me.
Re: '69 B-body drip rail moulding tool??? [Re: Big Squeeze] #1703097
11/26/14 10:55 AM
11/26/14 10:55 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
If that is your problem then the piece sounds like it is too loose. If it is then use plyers that have plastic tips or wrap duct tape on your normal plyers and while the trim is off. Gently squeeze the top and bottom edge towards each other. Examine the entire pirece and do that until it is uniform. Test fit it on the car. If it is still too loose do it again until it fits, then snap it on the car. Trying to squeeze it onto the car will not work.
Be patient and take your time. Do it a little at a time.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: '69 B-body drip rail moulding tool??? [Re: MOPARMIKE69] #1703098
11/27/14 12:56 AM
11/27/14 12:56 AM
Missouri
3
3_RTs Offline
3_RTs  Offline
Missouri
Yes, there are two different drip rail trims, one for vinyl top, and one for non-vinyl top. The non-vinyl top trim opening has an average measurement of about .375", while the vinyl top trim opening is about .435" on average. Of course the actual measurements may vary as much as .030" from the average.
I've polished and sold many sets over the years and conclude that if the opening measurement (measure 5 or 6 places)is above .410", it probably fits on a vinyl top car. If the opening measures below .400", it fits a non-vinyl car.
