Re: '69 B-body drip rail moulding tool???
[Re: Stanton]
#1703093
11/25/14 12:31 PM
11/25/14 12:31 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
There is for sure two different drip rail trim on these cars. One for vinyl top and one without vinyl top. Like already said you can't use trim that is not vinyl top trim. However the repop trim only comes in one size that can be used on both. I just installed some of the repop on a vinyl top car for a customer and it went on easy. The repop stainless is way less thick (made cheaper) than original so it is easier to install. Here is a picture of how I trim the top so the stainless will snap on and still hold the top edge of the vinyl.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: Big D A12]
#1703094
11/25/14 12:42 PM
11/25/14 12:42 PM
Posts: 18,160 Mass
DAYCLONA
Mass
is the drip rail trim you are using for a vinyl roof car? i know for sure on 71's there are 2 different drip rail trims vinyl or no vinyl.. it might be the same thing for 69's also its just something to research that could help you out some.
There are two different mouldings in 69. If you are trying to put the non vinyl top trim over a vinyl top, not going to happen.
Some other tips. Only leave the top about 1/2 way down the face of the drip rail. Don't bond the top to the face. This gives the top some flexibility when snapping on the trim plus with time it will be less likely to shrink in the gutter line and crack. So I have been told.
The only tool I use is my hands. I don't know of anything else that works well, on or off.
Hope this helps.
...I only use my thumbs and palm of my hand to remove or install drip rail molding
[Re: Big D A12]
#1703096
11/25/14 08:15 PM
11/25/14 08:15 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
i wasn't 100% sure on 69's, but just by reading his problem it sounded like he was using the wrong part to me. ![](/ubbthreads/images/graemlins/smile.gif)
