Cast iron world RB block mods for pushrod oiling #1702961
11/24/14 07:28 PM
11/24/14 07:28 PM
Nebraska
TT5 Valiant Offline OP
Nebraska
I have a complete world products RB engine with B1MC heads that's I want to convert to pushrod oiling. I know that I need different pushrods and lifters. I'm going to switch to T&D paired rockers to. What needs to be done to the block?
Re: Cast iron world RB block mods for pushrod oiling [Re: TT5 Valiant] #1702962
11/24/14 07:36 PM
11/24/14 07:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Other than block the oil feeds to the heads .... which you probably don't really need to do ... nothing that I am aware of.
Re: Cast iron world RB block mods for pushrod oiling [Re: TT5 Valiant] #1702963
11/24/14 07:38 PM
11/24/14 07:38 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Curiosity leads me to ask, assuming with your cylinder head choice this is a compitition engine only, correct? If so why would you want pushrod oiling?
Re: Cast iron world RB block mods for pushrod oiling [Re: Jerry Kathe] #1702964
11/24/14 07:53 PM
11/24/14 07:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Because he is changing his rockers from a shaft mount system to paired rockers .
Re: Cast iron world RB block mods for pushrod oiling [Re: Jerry Kathe] #1702965
11/24/14 07:58 PM
11/24/14 07:58 PM
Nebraska
Nebraska
I want to run a larger cam/ spring pressure and don't want to chance the Koffel's rockers that I have. I'm pretty sure the only way to oil T&D paired rockers is by the pushrods. I do not want to spray bar oil either.
Re: Cast iron world RB block mods for pushrod oiling [Re: TT5 Valiant] #1702966
11/24/14 08:08 PM
11/24/14 08:08 PM
AndyF Offline
AndyF  Offline
Just drop the new lifters and pushrods in place and you'll have pushrod oiling. I use pushrod oiling + valve cover oiling for my 514 engine.
I have Jesel rocker arms and the pushrod cups burned up with valve cover oiling. I added pushrod oiling using Crane roller lifters and the problem went away.
Re: Cast iron world RB block mods for pushrod oiling [Re: TT5 Valiant] #1702967
11/24/14 08:18 PM
11/24/14 08:18 PM
Jerry Kathe Offline
Jerry Kathe  Offline
FWIW....I have been using T&D paired with Trend pushrods for eons.....no failures.
I depend on the rods to oil the lifters and my spray bar is used to cool the springs with the splash lubricating the rockers and pushrods.
A pushrod full of oil is going backwards in reducing component weight....its difficult to get a stable pushrod that is also desirable weight. Food for thought.
Re: Cast iron world RB block mods for pushrod oiling [Re: AndyF] #1702968
11/24/14 08:25 PM
11/24/14 08:25 PM
Nebraska
Nebraska
Thanks for the info guy's! So any roller lifter that's set up for pushrod oiling? I currently have Isky red zone so I would probably get these again with the oiling option.
Re: Cast iron world RB block mods for pushrod oiling [Re: TT5 Valiant] #1702969
11/24/14 08:28 PM
11/24/14 08:28 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
You will need to restrict oiling with bushings. Otherwise you will have too much oil up top. So....I would bush the lifter bores.
Re: Cast iron world RB block mods for pushrod oiling [Re: camastomcat] #1702970
11/24/14 08:36 PM
11/24/14 08:36 PM
Nebraska
Nebraska
Can I restrict the oil with the pushrod hole or jet?
Re: Cast iron world RB block mods for pushrod oiling [Re: camastomcat] #1702971
11/24/14 08:40 PM
11/24/14 08:40 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
most pushrod company offer restrictor ends in the pushrods..... a .030" works perfect in most combos...
Re: Cast iron world RB block mods for pushrod oiling [Re: TT5 Valiant] #1702972
11/24/14 10:28 PM
11/24/14 10:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My lifter bores are bushed, T&D paired rockers. .080" feed hole in the bushing, Two .110" holes in each tappet, pushrods were about .110". Way to much, motor would only carry about 45psi with the pump relief valve adjuster screwed all the way in. I epoxied my tappets and drilled one feed in each to .040". Worked great. I read about another way which I think might even work better. Press a roll pin in the pushrod.
Doug
