Page 1 of 9 1 2 3 4 5 6 7 8 9
FORD 8.8 REAR................ #1702524
11/24/14 12:46 AM
11/24/14 12:46 AM
State of confusion
Thumperdart Offline OP
State of confusion
So what`s the deal on these in Mopars and how tough and how much $$$$$......................
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702525
11/24/14 01:10 AM
11/24/14 01:10 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Great rear axels from what I hear. Cheap too. Id consider the change myself.
Re: FORD 8.8 REAR................ [Re: Sport440] #1702526
11/24/14 01:18 AM
11/24/14 01:18 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Take less power to run also.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: FORD 8.8 REAR................ [Re: 440W8 Duster] #1702527
11/24/14 02:11 AM
11/24/14 02:11 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
5x4.5 bolt pattern, correct width with disc brakes for $200? Easy to buy and install. Simple logic for some people on a budget. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702528
11/24/14 02:12 AM
11/24/14 02:12 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Cheap, somewhat light and plentiful is about it.
Standard oem equipment for your "notch" mustang small tire racer. (Basic source of popularity)
Very simular to a 12 bolt chevy, but not as strong. Thin wall, small diameter axle tubes that bend easy, taper tube ends, c-clip axle retention.
To really make something out of one of these requires as much work and $$ as anything else and in some cases more..
Re: FORD 8.8 REAR................ [Re: Jerry Kathe] #1702529
11/24/14 02:50 AM
11/24/14 02:50 AM
State of confusion
State of confusion
Thaught I`d ask but figured it was too good 2 be true...........
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702530
11/24/14 04:50 AM
11/24/14 04:50 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you are going to spend money on an "upgraded" rear for your car.......that is NOT the one to start with. May as well use a 12 bolt
Monte
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702531
11/24/14 04:55 AM
11/24/14 04:55 AM
Q
Quicktree Offline
Quicktree  Offline
Q
don't waste your time, go straight to a 9"
Re: FORD 8.8 REAR................ [Re: Quicktree] #1702532
11/24/14 05:21 AM
11/24/14 05:21 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
We used to do a lot of 8.8s where I used to work. One thing you always had to check was the tube ends. We found a lot of them welded on crooked from the factory.
Re: FORD 8.8 REAR................ [Re: slantzilla] #1702533
11/24/14 12:52 PM
11/24/14 12:52 PM
State of confusion
State of confusion
Guess I got my answers..............don`t know anything about em and was curious and don`t want a Dana under my car.
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702534
11/24/14 01:15 PM
11/24/14 01:15 PM
Jerry Kathe Offline
Jerry Kathe  Offline
If your looking for a change..just do a 9".
Parts are plentiful and they can be built light and strong.
Back in '96 I was doing all the stuff on a competitive comp eliminator car when the drop out 12 bolt centers sections for the 9" fords were introduced by strange. We built one and plugged it in only to be disappointed with absolutely no change anywhere in performance.....only a big dent in the budget. So fwiw....there you go.
Re: FORD 8.8 REAR................ [Re: Jerry Kathe] #1702535
11/24/14 01:22 PM
11/24/14 01:22 PM
State of confusion
State of confusion
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702536
11/24/14 02:26 PM
11/24/14 02:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have the perfect 9" Strange center section for you. 4.10 gears and a Lenco billet locker. brand new
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702537
11/24/14 02:30 PM
11/24/14 02:30 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The easy "hot ticket" to find is the 8.8 out of an Explorer that came with the factory Discs and a Factory Auburn 3.73 or 4.10 Posi. The explorers also came with 31 spline axles and with rear discs/Calipers you don't have to worry about C clip eliminators on a street car unless you're running 10.99 or quicker IIRC....unless you switched to drums of course (for whatever reason).
And you can both shorten the 59.5" width AND center the pinion by shortening the longer tube 3" and using 2 of the shorter side axles. You wind up with a 56.5" end to end which is perfect for A bodys and narrowed B/E's.
Not what I'd put in a track only car but for a street/strip car it's tough to beat, not that they're so great it's just that it seems what people are asking for even 'run of the mill" open 8 3/4 Hogs heads and housings is getting pricey enough that you might consider other options.
Stephen Daurity talked me into putting an Explorer 8.8 in my 66 Valiant Wagon, if he says they're strong enough that's good enough for me.
We're going to perimeter weld the axle tubes once it's all back together for extra strength.
WIZE
In Car:
Re: FORD 8.8 REAR................ [Re: Quicktree] #1702538
11/24/14 02:35 PM
11/24/14 02:35 PM
State of confusion
State of confusion
I WISH Quick but it`s just not in the cards right now but SOON if things keep improving. Not sure on the width on mine but it`s stock unit out of a 70 something Duster.
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702539
11/24/14 03:19 PM
11/24/14 03:19 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
A coworker is running a 8.8 in his Drag Radial Mustang. Has a 632 BBC running 8.30's. I personally wouldn't run one at that speed, but it has held up for him.
Jeff
69 GTX 68 Road Runner
Re: FORD 8.8 REAR................ [Re: JERICOGTX] #1702540
11/24/14 03:39 PM
11/24/14 03:39 PM
State of confusion
State of confusion
Jeff
Seems crazy fast unless he spared no expense I guess..............
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702541
11/24/14 06:12 PM
11/24/14 06:12 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Why not a Dana 60 dom?
Mopar Performance
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702542
11/24/14 07:03 PM
11/24/14 07:03 PM
gregsdart Online content
gregsdart  Online Content
Dom, I put an explorer 8.8 rear in my 65 street Dart. I found a 3.55 ratio rear with discs. Along with checking the gears, look at the axles for wear where the grease seal rides next to the outer wheel bearing. Also, there can be wear on the pinion seal area. There are repair sleeves to fix this for the pinion, and special bearings that move the seal for the axle problem. Be sure and grab the Metric bolts for the companion flange and also the driveshaft flange if the thing was torched off at the bone yard. That way you might save some $$ for a drive shaft build. The brake lines are similar and if I recall I used two passenger side rubber lines from an 8.8 and a couple of 1/8 steel lines from Auto Zone to hook to the stock Mopar single line from the MC. I would think the Explorer axle tubes are plenty stout, and memory serves me right they are 3 1/4 inch diameter. You might want to weld them to the center section though, just for grins, or if you run slicks.
Be sure and spend the $$ for the best rear you can find, as I didn't, and the repair costs added up real fast.
Re: FORD 8.8 REAR................ [Re: gregsdart] #1702543
11/24/14 09:10 PM
11/24/14 09:10 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
a lot of guys down here are using Toyota Hilux ute diffs . Supposed to be a poor mans 9" . Lots of ratio choices and aftermarket parts .
5 x 4.5" pattern too .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
