Cowl vent, electric solenoid? #1702320
11/23/14 06:38 PM
11/23/14 06:38 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
After liberal amounts of penetration oil I got my cowl vent moving freely with the under dash handle, my question is it looks like a pretty easy install of replacing the handle with an electric solenoid to open and close it. Anybody do this?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Cowl vent, electric solenoid? [Re: AZ_A12_BEE] #1702321
11/23/14 06:39 PM
11/23/14 06:39 PM
Dreaming of the 808
Dreaming of the 808
Handle
Re: Cowl vent, electric solenoid? [Re: AZ_A12_BEE] #1702322
11/23/14 06:47 PM
11/23/14 06:47 PM
E
earlymopar Offline
earlymopar  Offline
E
Yes but it depends on what you want and why. I Personally I don't see why would someone spend money and time on this and add complexity to a mechanism that already has a very simple and effective means to operate it. but, if you like "bells and whistles" by all means go for it.
EM
Re: Cowl vent, electric solenoid? [Re: AZ_A12_BEE] #1702323
11/23/14 06:58 PM
11/23/14 06:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Instead of a solenoid I would use a linear actuator.
http://www.progressiveautomations.com/ac...CFRZqfgodhyQATw
Re: Cowl vent, electric solenoid? [Re: John_Kunkel] #1702324
11/23/14 07:18 PM
11/23/14 07:18 PM
Dreaming of the 808
Dreaming of the 808
John, are they adjustable so I can vary the amount I open it? Also I only need about 2-3 inches of travel. Are there lighter duty ones, I probably need about 20 pounds at most.
Re: Cowl vent, electric solenoid? [Re: AZ_A12_BEE] #1702326
11/24/14 04:09 PM
11/24/14 04:09 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
way back about 25 years ago I made the cowl vent on my wifes car open with a rear wiper motor that I got from the junk yard.
can't till you what car it came from, I picked up a bunch of them at the time and used one.
i took it apart and welded a rod to the arm inside and mounted it under the vent.
I had to time it to be closed, but it worked great
or you can try one of these.
http://www.yogisinc.com/index.cfm/page/ptype=product/product_id=9916/prd9916.htm
http://www.hotrodhardware.com/index.cfm/page/ptype=product/product_id=2606/prd2606.htm
Re: Cowl vent, electric solenoid? [Re: AZ_A12_BEE] #1702327
11/24/14 05:32 PM
11/24/14 05:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sure, they come in different strokes/forces...click the links on the left.
http://www.progressiveautomations.com/ac...ze-c-16_55.aspx
The idea is to power it with a double-pole/double-throw toggle stitch...toggle it open as much as you want and stop then toggle it closed.
Re: Cowl vent, electric solenoid? [Re: John_Kunkel] #1702328
11/25/14 02:38 PM
11/25/14 02:38 PM
dogdays Offline
dogdays  Offline
I'd take Ron's idea a bit farther, use the windshield wiper motor and a linkage to make the vent go up, down, up, down like Pac Man.
R.
Re: Cowl vent, electric solenoid? [Re: dogdays] #1702329
11/25/14 04:01 PM
11/25/14 04:01 PM
Dreaming of the 808
Dreaming of the 808
R.
The linkage is all there, I just need a linear actuator to replace the handle
Re: Cowl vent, electric solenoid? [Re: AZ_A12_BEE] #1702330
11/26/14 03:12 AM
11/26/14 03:12 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Get one of the kits that Ron linked, or maybe try a modern power window motor that senses stops.
BTW, did you try the oil on the WS screws in your other post? I'd soak the frame in some Evaporust, then penetrating oil before applying heat.
Re: Cowl vent, electric solenoid? [Re: RodStRace] #1702331
11/26/14 01:26 PM
11/26/14 01:26 PM
Dreaming of the 808
Dreaming of the 808
Ron. I'm soaking the screws with PB blaster, I will give it a few days
Re: Cowl vent, electric solenoid? [Re: AZ_A12_BEE] #1702332
12/09/14 02:27 PM
12/09/14 02:27 PM
Strasburg CO.
dartracer Offline
dartracer  Offline
Strasburg CO.
What about a rear pop out window motor from a Chrysler mini van. They are in or out and only move about 2 inches, grab the switch also.
Re: Cowl vent, electric solenoid? [Re: dartracer] #1702333
12/09/14 09:48 PM
12/09/14 09:48 PM
dogdays Offline
dogdays  Offline
I'm still holding out for the Pac-Man approach, vent "gobbling" up the road like Pac-Man gobbled up the pellets.....
R.
Re: Cowl vent, electric solenoid? [Re: dogdays] #1702334
12/10/14 11:54 AM
12/10/14 11:54 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
R.
68 Barracuda Formula S 340
