Re: Bell /scattershield question?
[Re: snuggles]
#170198
12/18/08 06:29 PM
12/18/08 06:29 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Do you already own the tools to check it's concentricity and runout?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: snuggles]
#170200
12/18/08 06:45 PM
12/18/08 06:45 PM
jbc426
West Coast, USA
That was the main thing with them. There are several choices available besides Lakewood.
[Re: snuggles]
#170201
12/19/08 12:43 AM
12/19/08 12:43 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I dont think youll need a 143 tooth flywheel on a 340.
Most big block dont need one.
[Re: snuggles]
#170202
12/19/08 10:41 AM
12/19/08 10:41 AM
Posts: 8,144 Arkansas
340727dart
Arkansas
Isn't the 130 tooth flywheel for use with a 10.5" clutch and the 143 for an 11.0" clutch?
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: 340727dart]
#170204
12/19/08 06:43 PM
12/19/08 06:43 PM
jbc426
West Coast, USA
My Lakewood scatter shield says is compatible with both, however according to the directions from TTI, there are starter fitment issues with the 143 tooth and TTI's.
I used the 130 tooth flywheel and the Street Twin from McCleod. The bell had to be both shimmed and have offset dowels, but it wasn't that bad.
