Bell /scattershield question? #170197
12/18/08 06:08 PM
12/18/08 06:08 PM
Pizza Bucket
snuggles Offline OP
snuggles  Offline OP
Pizza Bucket
Anything I need to know before I order one? Fitment issues? 130 or 143? Car is 74 a body with 68 340. Thanks
Re: Bell /scattershield question? [Re: snuggles] #170198
12/18/08 06:29 PM
12/18/08 06:29 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Do you already own the tools to check it's concentricity and runout?
Re: Bell /scattershield question? [Re: jbc426] #170199
12/18/08 06:38 PM
12/18/08 06:38 PM
Pizza Bucket
snuggles Offline OP
snuggles  Offline OP
Pizza Bucket
No I'll borrow or buy if I need to.
Re: Bell /scattershield question? [Re: snuggles] #170200
12/18/08 06:45 PM
12/18/08 06:45 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
That was the main thing with them. There are several choices available besides Lakewood.
Re: Bell /scattershield question? [Re: snuggles] #170201
12/19/08 12:43 AM
12/19/08 12:43 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I dont think youll need a 143 tooth flywheel on a 340.
Most big block dont need one.
Re: Bell /scattershield question? [Re: snuggles] #170202
12/19/08 10:41 AM
12/19/08 10:41 AM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Isn't the 130 tooth flywheel for use with a 10.5" clutch and the 143 for an 11.0" clutch?
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Bell /scattershield question? [Re: snuggles] #170203
12/19/08 05:55 PM
12/19/08 05:55 PM
Columbia, Missouri
dtedler Offline
dtedler  Offline
Columbia, Missouri
What type of scattershield are your going to use? What transmission? You will need to dial indicate the bell housing either way. Offset dowels are available from RobbMc and are the best time saver in the world. If you are using a Lakewood, take your time and triple check everything and make sure everything is tight, not just hand tight.
The 130 tooth flywheel will accept a 10.95" clutch that almost everyone has. 130 tooth is the way to go. The 143 tooth flywheels were used on big block applications and trucks. A majority of the aftermarket companies are not manufacturing the 143 tooth flywheel any longer since the demand has gone away.
Tony Edler
Mopar Sales and Support
Classic Mopar 5 Speed
Re: Bell /scattershield question? [Re: 340727dart] #170204
12/19/08 06:43 PM
12/19/08 06:43 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My Lakewood scatter shield says is compatible with both, however according to the directions from TTI, there are starter fitment issues with the 143 tooth and TTI's.
I used the 130 tooth flywheel and the Street Twin from McCleod. The bell had to be both shimmed and have offset dowels, but it wasn't that bad.
Re: Bell /scattershield question? [Re: snuggles] #170205
12/20/08 08:39 AM
12/20/08 08:39 AM
Pizza Bucket
snuggles Offline OP
snuggles  Offline OP
Pizza Bucket
Thanks.
