How to get brighter headlights? #1701924
11/22/14 08:51 PM
11/22/14 08:51 PM
ky.
K
kenworth_goose Offline OP
K
ky.
I know there is something I can buy to get both the dim and bright lights on at the same time but can't seem to find it. Help. I want my lights on my 99 ram brighter.
Re: How to get brighter headlights? [Re: kenworth_goose] #1701925
11/22/14 09:06 PM
11/22/14 09:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried Sylvania silver star bulbs? How clear are the lenses? There is the problem of blinding oncoming drivers which you don't really want to do.
Re: How to get brighter headlights? [Re: kenworth_goose] #1701926
11/22/14 09:49 PM
11/22/14 09:49 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
Re: How to get brighter headlights? [Re: stumpy] #1701927
11/22/14 09:52 PM
11/22/14 09:52 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
those Sylvania Silverstar bulbs are nothing but marketing hype...
if you want to upgrade the bulbs, and have 14V at the terminal w/ no voltage drop (meaning all electrical supply problems are solved first), then HIR bulbs are the best upgrade for anyone who doesn't want to step up to HID lights and the super expensive housing modifications to make them work.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: How to get brighter headlights? [Re: kenworth_goose] #1701928
11/23/14 01:00 AM
11/23/14 01:00 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
You can also use a relay and power your lights straight from the battery.
Re: How to get brighter headlights? [Re: shanker] #1701929
11/23/14 01:47 AM
11/23/14 01:47 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Well it's marketing hype that made it a lot easier for me to see at night on the three cars I installed the Ultras in. So that's good enough for me to recommend them.
Re: How to get brighter headlights? [Re: stumpy] #1701930
11/23/14 05:54 AM
11/23/14 05:54 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Re: How to get brighter headlights? [Re: hp383] #1701931
11/23/14 11:25 AM
11/23/14 11:25 AM
IN
ahy Offline
ahy  Offline
IN
As posted, the relay's help a lot. The fender relay is a handy place to pull the power on a MOPAR. Upgraded halogen headlights + bulbs help a lot also. The two together made a huge difference on my F250. I used LMC stuff... which is also offered for Dodge. If you get the harness kit you will also need fuses or circuit breakers from the parts store.
http://www.lmctruck.com/icatalog/dc/full.aspx?Page=33
Re: How to get brighter headlights? [Re: hp383] #1701932
11/23/14 03:00 PM
11/23/14 03:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
This hasn't been mentioned often or I missed it, is it normal that low beams turn off when high beams go on? In the posted diagram, would not adding a simple diode between the control circuits (86) of the two relays, activate both relays when Hi's are turned on, providing additional light, easily? This would eliminate any need for a previously mentioned "smart box" on relay upgrade systems, correct?
Re: How to get brighter headlights? [Re: jcc] #1701933
11/23/14 05:18 PM
11/23/14 05:18 PM
Salem
Grizzly Online tonguue
Moparts Proctologist
Grizzly  Online Tonguue
Salem
I just cracked open the relay and blocked the lever inside to get hi/lo at the same time. Took about 30 seconds to do and was free.
Mo' Farts
Moderated by "tbagger".
Re: How to get brighter headlights? [Re: Grizzly] #1701934
11/23/14 09:21 PM
11/23/14 09:21 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
However running hi and low at the same time will create more heat and shorten lifespan.
Re: How to get brighter headlights? [Re: moparborn] #1701935
11/23/14 11:08 PM
11/23/14 11:08 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
This.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: How to get brighter headlights? [Re: moparborn] #1701936
11/24/14 01:12 AM
11/24/14 01:12 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Especially since the return to ground will carry about double the current it was designed for.
PS. I don't know if any of this is relevant to the OP, since he is asking about an '99 Dodge Ram. I know it doesn't use a sealed/halogen sealed lamp...
Re: How to get brighter headlights? [Re: moparborn] #1701937
11/24/14 01:32 AM
11/24/14 01:32 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Possibly causing *both* filaments to go out. And lights go out when you need to use them.
To make a light brighter, you need to send it more voltage and/or reduce the voltage drops (as has been mentioned).
