I had a set of those MP cut to length pushrods once. It's the threads/distance below the rocker arm that counts as there's a squirt hole in the rocker arm under the arm that extends out & contacts the valve & the round nub/pushrod cup needs to be at the right distance so the squirt hits it and that the pushrod/threaded ball angle ain't too excessive at full lift and enough threads above the rocker to use the locknut & could mill the rocker face there thinner if needed. then you need the right preload.
www.hughesengines.com has an orange sheet & has additional checks such as at 50 or 60% of cam lift (depends if SB or BB) that when viewed from the end of the eng front or rear that the pushrod/rocker are at a right angle at that lift percentage. Then there is the wipe pattern on the valve stem tip which is more a function of the height of the (5) pedestals & you can raise the shaft with shims and mill the notches deeper to go the other way & sometimes the rocker arm that contacts the valve ain't long enough, then there's coil bind/retainer to seal/retainer to rocker clearances
. Alot to check. Definitely buy or make an adjustable pushrod & mockup/check EVERYTHING & go from there. I would find the preload that YOU intend to go with & JBweld a junk hyd lifters' retainer solid at that height & use it for mockup checks
