Probe Industry Pistons, any good? #1701878
11/22/14 05:24 PM
11/22/14 05:24 PM
Cab_Burge Offline OP
I'm looking to make another pump gas street RB stroker motor to sell or use. I have a set of Eagle 6.800 long BB Chevy type rods and several new RPM 4.150 stroker cranks that I can have offset ground down to 2.200 rod size and 4.250 stroke. Probe has a reverse dome SRS forged shelf piston for this application at a reasonable price(cheaper than any one else I can find) that I can use to get the mechanical compression ratio where I would want it. I've never used any of there pistons so I'm wondering how good or bad are they The part number I want to use is thier part #14896-.060, any of you out there use these If so what are your thoughts about using them agian on another motor like mine All comments appreciated, even from show car guys
Re: Probe Industry Pistons, any good? [Re: Cab_Burge] #1701879
11/22/14 05:42 PM
11/22/14 05:42 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Had a set some years ago in a NSS Max Wedge car a friend and I ran together, had good luck with them , I would buy another set.
Joey
Re: Probe Industry Pistons, any good? [Re: Cab_Burge] #1701880
11/22/14 06:49 PM
11/22/14 06:49 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I've used them in SBC applications. No problems.
If you like drag racing, support your local track.
Re: Probe Industry Pistons, any good? [Re: Cab_Burge] #1701881
11/22/14 07:42 PM
11/22/14 07:42 PM
Colorado
funnycar65 Offline
funnycar65  Offline
Colorado
Whats thier price for pistons?
Re: Probe Industry Pistons, any good? [Re: funnycar65] #1701882
11/22/14 08:29 PM
11/22/14 08:29 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
The owner, Mark O’Neal, is a regular on the ‘Bullet. He seems to stand behind his products. Most people that use his pistons don’t have any complaints.
Re: Probe Industry Pistons, any good? [Re: Cab_Burge] #1701883
11/23/14 12:27 AM
11/23/14 12:27 AM
ky
68roadrunner Offline
ky
got a set in my road runner, 440 flat top piston zero deck. havent had it apart but once and all was good then, may take it apart this winter
they was the lightest i could find at the time, which is what i wanted on a stock rod
Re: Probe Industry Pistons, any good? [Re: 68roadrunner] #1701884
11/23/14 01:27 AM
11/23/14 01:27 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Quality product at an affordable price. My last engine had a set and the new one will too. Can't wait for them to get here.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Probe Industry Pistons, any good? [Re: BBR] #1701885
11/23/14 02:55 AM
11/23/14 02:55 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
years ago I was in Lancaster and stopped by and talked with the owner. I don't know if it has changed owners over the years but back then he was a relative of ross pistons. He basically did the engineering and had Ross do the work with there blanks and equipment but to his specs
Re: Probe Industry Pistons, any good? [Re: littleVAL] #1701886
11/23/14 04:00 AM
11/23/14 04:00 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
TRUE!
Re: Probe Industry Pistons, any good? [Re: Biginchmopar] #1701887
11/24/14 11:07 PM
11/24/14 11:07 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
currently running them in my smallblock and have been in there for going on 6 seasons, nice looking piston and no problems.
Re: Probe Industry Pistons, any good? [Re: Cab_Burge] #1701888
11/24/14 11:56 PM
11/24/14 11:56 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
1875+ passes and counting on the sm block stroker in the Demon, with Probe pistons, and never out of the block since built.
Re: Probe Industry Pistons, any good? [Re: qwkmopardan] #1701889
11/25/14 12:10 AM
11/25/14 12:10 AM
Thanks to all of you who help me decide to buy them I ordered them today I had called them last week to verify some of the blueprint specs on the compression ratio and to check stock, they are not a large volume part number so it wil be 3 to 6 weeks before I get them Thanks again
