8 3/4 from a pick-up #170174
12/18/08 05:31 PM
12/18/08 05:31 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
I've got an 8 3/4 from an older pick-up. I'm thinking about having Dutchman narrow it to fit my A body. Is there enough length on the axles to do this?
Re: 8 3/4 from a pick-up [Re: elmor] #170175
12/18/08 06:25 PM
12/18/08 06:25 PM
yes
Re: 8 3/4 from a pick-up [Re: elmor] #170176
12/18/08 06:42 PM
12/18/08 06:42 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
We did the same thing on one of my scamps that
had the tiny rear end in it.
The truck had the same spline but was a thicker
shaft. We put a cheep spool in it we found at
a swap meet and a rebuilt 360 in it, and pounded
the pi$$ out of it for a while. Full time posi
is fun with little 70R/14 tires roasting for
a couple hundred ft.
Snap your neck, mega G-force launch, is all I want!
Re: 8 3/4 from a pick-up [Re: BDS871Cuda] #170177
12/18/08 10:19 PM
12/18/08 10:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
We used shortened truck axles in my dads Duster back when we ran the iron head 360. Glad we found this before something bad happened.
Re: 8 3/4 from a pick-up [Re: J_BODY] #170178
12/18/08 11:00 PM
12/18/08 11:00 PM
scratchnfotraction Offline
depends on if the axle is a good canadate for shortening
some are tapperd down and are not thick enuff to respline
but most truck and c-body axle are good canadates for a re spline
measure the axle to see if it tappers down in the area that the a-body axle will be
29" IIRC
and some truck axles are the 5 on 5.5 wbp also
Re: 8 3/4 from a pick-up [Re: scratchnfotraction] #170179
12/18/08 11:15 PM
12/18/08 11:15 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
whats a rough $ estimate on cutting and resplining a set of axles?
Re: 8 3/4 from a pick-up [Re: nomore65BelvJim] #170180
12/18/08 11:28 PM
12/18/08 11:28 PM
moser did some for me a long time ago about 65$
seems they narrowed the housing in that same price range too
give them a call
I got a-body axles with green bearings,large brake offset.5 on 4.5 wbp 299$ for a set
got an a body housing in 2000 for 225$
try doctor diff here on the board too
Re: 8 3/4 from a pick-up [Re: nomore65BelvJim] #170181
12/18/08 11:47 PM
12/18/08 11:47 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Dutchman wants $90 to shorten the pair of axles, $120 to narrow the housing, and another $120 to remove and install new spring perches.
Re: 8 3/4 from a pick-up [Re: elmor] #170182
12/19/08 11:20 AM
12/19/08 11:20 AM
moser charged me 25$ for the perches and 25$ labor to weld them ona housing
I got an old magazine with a moser add
65$ for respline or narrowing a housing
thats why I used them
great price great workmanship 5 day turn around
last one I did with moser it was 225$ for an A-body housing
50$ for perches/labor
299$ for axles with greens and large brake offset
plus shipping
560-570$ IIRC
saved my stuff and just had them send it all to me from there...5 days and fit right the first time
still hammering it 8 yrs later
try them and doctor diff
good luck
Re: 8 3/4 from a pick-up [Re: scratchnfotraction] #170183
12/19/08 12:16 PM
12/19/08 12:16 PM
hook your tape on the outside of the flange & measure out to where it starts to taper, if you have at least 28" you're good. I think it's $110 for the housing & $110 for the axles & $55 for the perches(plus new perches) plus the shipping to Portland Indiana & back. Be sure & tell them to relocate the perches on the other side of the(truck) housing(I forgot to do that & they didn't catch it either ) & they will relocate them at 43.125" & factory was 43.02". that amt I wouldn't think it'd be a problem but I wanted mine factory perfect so I gave them that dimention rather than telling them "to A body dimentions" .
Re: 8 3/4 from a pick-up [Re: elmor] #170184
12/19/08 05:25 PM
12/19/08 05:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pic below illustrates the acceptable/unacceptable limits for an A body axle.
Re: 8 3/4 from a pick-up [Re: RapidRobert] #170185
12/21/08 06:09 AM
12/21/08 06:09 AM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Dutchman's located in Portland, Oregon, not Portland, Indiana.
Re: 8 3/4 from a pick-up [Re: elmor] #170186
12/21/08 03:18 PM
12/21/08 03:18 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Moser is located in Portland Indiana, not Portland Oregon.
Re: 8 3/4 from a pick-up [Re: DoctorDiff] #170187
12/23/08 07:42 PM
12/23/08 07:42 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
WHAT ARE THE ODDS THAT 2 DIFFERENT REAR END BUILDERS WOULD BE LOCATED IN CITIES OF THE SAME NAME,BUT LOCATED 2/3 OF THE COUNTRY APART FROM EACH OTHER? DOC, IF I WANT TO USE AFTERMARKET AXLES, CAN I STILL USE THE BACKING PLATES AND DRUMS FROM MY REAREND?
Re: 8 3/4 from a pick-up [Re: elmor] #170188
12/23/08 07:52 PM
12/23/08 07:52 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
another option is a b body axle....it will work...but wheel offset is critical
Re: 8 3/4 from a pick-up [Re: elmor] #170189
12/23/08 08:29 PM
12/23/08 08:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the aftermarket axles are configured with the B, C, E body flange dimension (most are) the A body brake drums, shoes and backing plates won't work.
Re: 8 3/4 from a pick-up [Re: elmor] #170190
12/23/08 10:13 PM
12/23/08 10:13 PM
not very high. If your having the truck BBP 8&3/4 narrowed for your A body the drums/backing plates/shoes etc will still fit OK, they are just shortening the axles/housing inward to fit your A body. I would check the wheels/tires you intend to use as that MAY slightly change how much you want them to narrow it. Measure twice cut once is good advice.
Re: 8 3/4 from a pick-up [Re: elmor] #170191
12/23/08 11:13 PM
12/23/08 11:13 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Stock A-body housings designed for 5 x 4" axles measures 52 5/8" wide. A 52" wide housing will yield an identical assembly width when used with standard 5 x 4 1/2" axle flange stand out.
Unfortunately, the stock housing ends get a little close to the perches, so I usually make (5 x 4 1/2" pattern) A-body housings 52 1/4" wide.
Re: 8 3/4 from a pick-up [Re: DoctorDiff] #170192
12/24/08 02:39 AM
12/24/08 02:39 AM
Doc is that with the perches at 43 or 43.125.
Re: 8 3/4 from a pick-up [Re: RapidRobert] #170193
12/24/08 11:41 AM
12/24/08 11:41 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Thats spring perches positioned at the correct, 43" measurement.
