Re: 8 3/4 from a pick-up
[Re: J_BODY]
#170178
12/18/08 11:00 PM
12/18/08 11:00 PM
Posts: 15,487 Florida
scratchnfotraction
depends on if the axle is a good canadate for shortening some are tapperd down and are not thick enuff to respline but most truck and c-body axle are good canadates for a re spline measure the axle to see if it tappers down in the area that the a-body axle will be 29" IIRC and some truck axles are the 5 on 5.5 wbp also
[Re: nomore65BelvJim]
#170180
12/18/08 11:28 PM
12/18/08 11:28 PM
scratchnfotraction
moser did some for me a long time ago about 65$ seems they narrowed the housing in that same price range too give them a call I got a-body axles with green bearings,large brake offset.5 on 4.5 wbp 299$ for a set got an a body housing in 2000 for 225$ try doctor diff here on the board too
[Re: elmor]
#170182
12/19/08 11:20 AM
12/19/08 11:20 AM
scratchnfotraction
moser charged me 25$ for the perches and 25$ labor to weld them ona housing I got an old magazine with a moser add 65$ for respline or narrowing a housing thats why I used them great price great workmanship 5 day turn around last one I did with moser it was 225$ for an A-body housing 50$ for perches/labor 299$ for axles with greens and large brake offset plus shipping 560-570$ IIRC saved my stuff and just had them send it all to me from there...5 days and fit right the first time still hammering it 8 yrs later try them and doctor diff good luck
[Re: scratchnfotraction]
#170183
12/19/08 12:16 PM
12/19/08 12:16 PM
RapidRobert
hook your tape on the outside of the flange & measure out to where it starts to taper, if you have at least 28" you're good. I think it's $110 for the housing & $110 for the axles & $55 for the perches(plus new perches) plus the shipping to Portland Indiana & back. Be sure & tell them to relocate the perches on the other side of the(truck) housing(I forgot to do that & they didn't catch it either ) & they will relocate them at 43.125" & factory was 43.02". that amt I wouldn't think it'd be a problem but I wanted mine factory perfect so I gave them that dimention rather than telling them "to A body dimentions" .
[Re: elmor]
#170188
12/23/08 07:52 PM
12/23/08 07:52 PM
340dart4spd
Parts Problem
Parts Problem
I've got an 8 3/4 from an older pick-up. I'm thinking about having Dutchman narrow it to fit my A body. Is there enough length on the axles to do this?
another option is a b body axle....it will work...but wheel offset is critical
