weird carb prob. #1701173
11/20/14 03:12 PM
11/20/14 03:12 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
1050 dom.8896.with the car running the secondaries wont close all the way.shut the car off and every thing snaps shut like it should.
Re: weird carb prob. [Re: bonefish] #1701174
11/20/14 03:20 PM
11/20/14 03:20 PM
Remove it from the intake and check the linkage underneath for loose screws Let us know what you find
Re: weird carb prob. [Re: bonefish] #1701175
11/20/14 03:23 PM
11/20/14 03:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Also, hold the carb up to a light and check the throttle butterflies for evenness in the venturies and loosten the screws and get em as even as possible then red locktite and you`re golden.
Re: weird carb prob. [Re: Thumperdart] #1701176
11/20/14 04:06 PM
11/20/14 04:06 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
well its workin great now.all I did was take it apart and check everything that was suggested.it all checked out good.but I did notice that my rear pumpshot adjustment was extra loose.so I tightened that up so there was a very slight gap and it works perfect.
Re: weird carb prob. [Re: bonefish] #1701177
11/20/14 04:09 PM
11/20/14 04:09 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
There is an adjustment for the secondary plates.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: weird carb prob. [Re: bonefish] #1701178
11/20/14 04:15 PM
11/20/14 04:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Normally zero gap unless you`re trying to delay/lean shot.
Re: weird carb prob. [Re: Thumperdart] #1701179
11/20/14 04:21 PM
11/20/14 04:21 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Normally zero gap unless you`re trying to delay/lean shot. that's actually why I had it loose but I guess there is a limit.but it worked great for awhile.theoretically you should be able to run a gap for a delayed shot.i still don't know why it was acting like that. but it will prob happen again when I somewhere where it will embarass me.
Re: weird carb prob. [Re: Thumperdart] #1701180
11/20/14 04:51 PM
11/20/14 04:51 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Why would you try to purposely create that situation?(trying to delay/lean shot)
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: weird carb prob. [Re: 1320Dart] #1701181
11/20/14 05:51 PM
11/20/14 05:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Some I know and study go to great lengths to "fine tune" every inch and that means sometimes slowing down or delaying shot based on fuel curve data.........
Re: weird carb prob. [Re: Thumperdart] #1701182
11/20/14 06:36 PM
11/20/14 06:36 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
that's exacly what I was trying to do.
Re: weird carb prob. [Re: bonefish] #1701183
11/20/14 06:52 PM
11/20/14 06:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
VERY doable yet VERY time consuming..............
Re: weird carb prob. [Re: 1320Dart] #1701184
11/20/14 08:46 PM
11/20/14 08:46 PM
I've seen a bunch of stock Holley Dominators as well as other D.P. come from Holley maladjusted like that Another one of the checks you need to perform beofre using any of them
Re: weird carb prob. [Re: Cab_Burge] #1701185
11/20/14 09:20 PM
11/20/14 09:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Another trick great for footbrake racers is to use a smaller secondary squirter if it`s too rich when nailed..........I`m messin w/that now on my junk.
