Installing Big Torsion Bars #1701162
11/20/14 03:07 PM
11/20/14 03:07 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I need a little bit of advice. The last time I put the torsion bars in, I had a lift at my disposal.
I slipped one out the other day and now I want to know if there is a better method to "index" them. I've already got shortened bumpstops so I'd like to keep the cars stance pretty low.
Can anyone outline a process for getting the hex lined up while not being able to lift the car up and down with the lift?
I'll have to raise and lower the control arm with a jackstand.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Installing Big Torsion Bars [Re: AlexP] #1701163
11/20/14 03:57 PM
11/20/14 03:57 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You'll need the nose supported with jack stands, then starting with suspension at full droop, jack under control arm until hex lines up.
Mopar to the bone!!!
Re: Installing Big Torsion Bars [Re: AlexP] #1701164
11/20/14 03:57 PM
11/20/14 03:57 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Car on a jackstand with the jack under the control arm?
If this doesn't provide enough travel you can always pop the ball joint.
- Stu Harmon
Re: Installing Big Torsion Bars [Re: feets] #1701165
11/20/14 04:10 PM
11/20/14 04:10 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
There aren't many possibilities are there? It's a hex and there is no way I could jack it up past about two sides of the hex.
Should I keep the screw fully tensioned or loose while doing this?
Re: Installing Big Torsion Bars [Re: AlexP] #1701166
11/20/14 04:19 PM
11/20/14 04:19 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Keep the screw loose.
That's normal for you, isn't it?
- Stu Harmon
Re: Installing Big Torsion Bars [Re: AlexP] #1701167
11/20/14 04:19 PM
11/20/14 04:19 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
One hex is 60 degrees to the next one.
You have to be pretty inventive to choose the wrong hex
Re: Installing Big Torsion Bars [Re: AlexP] #1701168
11/20/14 05:24 PM
11/20/14 05:24 PM
AndyF Offline
AndyF  Offline
I use a spanner wrench to adjust the hex in the lower control arm. If the indexing on the bar is correct you usually only need to twist the hex a little bit to get things to line up. I just built a simple spanner wrench that fits into the hex so I can easily twist it into alignment.
I will say that some of the torsion bar vendors don't seem to understand indexing. I've see a few bars that cannot be installed because the hex ends aren't where they need to be. If the ends aren't indexed correctly (function of car weight, ride height and bar stiffness) then you'll never get it installed.
Re: Installing Big Torsion Bars [Re: AndyF] #1701169
11/20/14 05:42 PM
11/20/14 05:42 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
These are MP 1.22" bars if it matters.
Re: Installing Big Torsion Bars [Re: AlexP] #1701170
11/20/14 09:17 PM
11/20/14 09:17 PM
AndyF Offline
AndyF  Offline
MP clocked their bars until you got to the larger sizes and then they didn't clock them. That may or may not work for your car.
Firm Feel is the only place that I know of who does it correctly. They clock each size a little differently in order to keep the adjustment screw in the middle of the range. As the bars get bigger the clocking needs to be reduced.
Re: Installing Big Torsion Bars [Re: AlexP] #1701171
11/20/14 09:37 PM
11/20/14 09:37 PM
Pikes Peak Country
TC@HP2 Online content
TC@HP2  Online Content
Pikes Peak Country
If you can't lift the car, you have to lift the control arm.
Set the car on jackstand, use a jack to raise the arm until the hexes align, slide it home. With the 1.22 MP bars, you will have to raise the lower arm up almost to its ride height postion before they align. Leave the adjusting bolt loose while installing. Tighten up to desire ride height after that.
Re: Installing Big Torsion Bars [Re: AlexP] #1701172
11/20/14 09:54 PM
11/20/14 09:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
It does.
