Re: Installing Big Torsion Bars
[Re: AlexP]
#1701163
11/20/14 03:57 PM
11/20/14 03:57 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You'll need the nose supported with jack stands, then starting with suspension at full droop, jack under control arm until hex lines up.
Mopar to the bone!!!
[Re: AlexP]
#1701164
11/20/14 03:57 PM
11/20/14 03:57 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Car on a jackstand with the jack under the control arm?
If this doesn't provide enough travel you can always pop the ball joint.
[Re: AlexP]
#1701166
11/20/14 04:19 PM
11/20/14 04:19 PM
feets
Senior Management
Senior Management
Irving, TX
Keep the screw loose. That's normal for you, isn't it?
[Re: AlexP]
#1701171
11/20/14 09:37 PM
11/20/14 09:37 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Can anyone outline a process for getting the hex lined up while not being able to lift the car up and down with the lift?
I'll have to raise and lower the control arm with a jackstand.
If you can't lift the car, you have to lift the control arm.
Set the car on jackstand, use a jack to raise the arm until the hexes align, slide it home. With the 1.22 MP bars, you will have to raise the lower arm up almost to its ride height postion before they align. Leave the adjusting bolt loose while installing. Tighten up to desire ride height after that.
