Re: M/T drag radials ??
[Re: 383man]
#1701102
11/20/14 11:19 AM
11/20/14 11:19 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
The sizing relationship between the MT DOT and non-DOT, and the Hoosier DOT and non-DOT is similar.
i.e. a 26 x 8.5 ET drag is roughly the same at a 26 x 10 ET Street
Is the section of your current tires measured, or what Hoosier lists? Section will vary depending on the rim width it was measured on. MT lists the section of that tire based on a 8.5" rim. How wide are your rims? There were some guidelines on rim width change to section width change, but I do not recall exactly what they were...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: 383man]
#1701104
11/20/14 11:54 AM
11/20/14 11:54 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
They compare the 295-65 to the 30x12.5 ET Street bias tire, but the bias ET Streets are listed by the section width, not tread width. A 28x12.5 ET Street is the same size as a 28x10.5 ET Drag. The 30x12.5 ET Street is basically the same size as a 29.5x10.5 ET Drag...fit the same on my car. If you can fit the 30x9 slick on there now, I'm almost positive the 295-65 radial will fit w/ no problems. I ran that tire for a long time on my cuda.
[Re: an8sec70cuda]
#1701105
11/20/14 04:03 PM
11/20/14 04:03 PM
Posts: 860 lancaster,california
johnnycuda
I have these tires on my 'Cuda on 10" wide wheels, I will measure tonight and post what the specs are on mine.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
