T-Stat question #1700939
11/19/14 09:20 PM
11/19/14 09:20 PM
Madison, Wisconsin
chrisnben Offline OP
Madison, Wisconsin
here's my thought for today- Why, when tested in a pan on the stove does a 180 degree thermostat open at 200? I tested two different ones- same result.
Things that make you crazy
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: T-Stat question [Re: chrisnben] #1700940
11/19/14 09:40 PM
11/19/14 09:40 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Because for the most part........a thermostat is VERY inaccurate apparatus...........LOL!!!......as you see.
Monte
Re: T-Stat question [Re: chrisnben] #1700941
11/19/14 09:42 PM
11/19/14 09:42 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Cheap stats are hit or miss. A good US made part should be close. Is your thermometer any good? At 200*, the water should be about starting to boil. And unless you put it under pressure, you can't get water above 212*.
Re: T-Stat question [Re: chrisnben] #1700942
11/19/14 11:27 PM
11/19/14 11:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If it is a a 180 stat that means it just barely starts to open at 180, it may be hard to see it starting to open with your face in a pan of hot steamy water, most of them will not be fully open till around 200. Even if you pull it out of the pan at 180* the open crack would be very small and the stat will be cooled a few degrees before you get it close enough to see the crack and probably closed.
Re: T-Stat question [Re: HotRodDave] #1700943
11/19/14 11:42 PM
11/19/14 11:42 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
when I test mine I notice when you cycle it the subsequent times it opens wider at 180, not fully but close.
Re: T-Stat question [Re: chrisnben] #1700944
11/20/14 02:09 PM
11/20/14 02:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
They should start to open then be fully opened at the stamped rating.............SHOULD. I boil all of mine and Stant are the best but harder to find.
Re: T-Stat question [Re: Thumperdart] #1700945
11/20/14 02:47 PM
11/20/14 02:47 PM
Madison, Wisconsin
Madison, Wisconsin
First one is a 440source 180; second is a NAPA superstat 180. I'm going to check with another thermometer today. The control was a meat thermometer, but was accurate at opening on both at 200 exactly. Report tonight.
Re: T-Stat question [Re: chrisnben] #1700946
11/20/14 03:06 PM
11/20/14 03:06 PM
dogdays Offline
dogdays  Offline
Oh, yeah, the high accuracy meat thermometer. All you know from your tests is they are consistent in opening temperature. Just a few degrees of ta turn of the head relative to the shaft and the meat thermometer isn't zeroed anymore.
R.
Re: T-Stat question [Re: chrisnben] #1700947
11/20/14 03:31 PM
11/20/14 03:31 PM
Which type of thermostat, standard or heavy duty with the schroud liket the motor homes came with? I like to buy and use the M.H type 160 degrees for the reason your seeing, slow opening
