Re: T-Stat question
[Re: chrisnben]
#1700941
11/19/14 09:42 PM
11/19/14 09:42 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Cheap stats are hit or miss. A good US made part should be close. Is your thermometer any good? At 200*, the water should be about starting to boil. And unless you put it under pressure, you can't get water above 212*.
Re: T-Stat question
[Re: chrisnben]
#1700942
11/19/14 11:27 PM
11/19/14 11:27 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If it is a a 180 stat that means it just barely starts to open at 180, it may be hard to see it starting to open with your face in a pan of hot steamy water, most of them will not be fully open till around 200. Even if you pull it out of the pan at 180* the open crack would be very small and the stat will be cooled a few degrees before you get it close enough to see the crack and probably closed.
Re: T-Stat question
[Re: HotRodDave]
#1700943
11/19/14 11:42 PM
11/19/14 11:42 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
when I test mine I notice when you cycle it the subsequent times it opens wider at 180, not fully but close.
