Roller Rockers - what's going on? #170049
12/18/08 03:33 PM
12/18/08 03:33 PM
Keminmaa
ArcticCuda Offline OP
Keminmaa
Comp Cams 1321-16 roller rockers has been in back order since August. Now I tried to buy Crane 64792-1 rockers. Answer: Availabele after 7 weeks...
What is going on? Do I have to buy China Rockers.
Pepe / Finland Europe
1970 Plymouth GTX 440-6
1970 Plymouth PPR Cuda 489-4
1971 Plymouth Duster Bad Romance 408-W2-8bbl
Re: Roller Rockers - what's going on? [Re: ArcticCuda] #170050
12/18/08 03:41 PM
12/18/08 03:41 PM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
Purchased some Harland sharp rockers from summit about a month ago. They showed up the next day.
Re: Roller Rockers - what's going on? [Re: ArcticCuda] #170051
12/18/08 03:43 PM
12/18/08 03:43 PM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
I had that problem earlier this fall. I ended up buying some crane gold 1.6 off ebag. Turned out to be a local moparts member He told me that the shafts were coming in out of spec (turned down too much if I remember correctly) from china that is why they are on back order. Not sure but everywhere I checked they were on back order. I am very happy with mine.
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: Roller Rockers - what's going on? [Re: ArcticCuda] #170052
12/18/08 04:04 PM
12/18/08 04:04 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
We have plenty of rockers in stock (1510S-16). Guarenteed for life against breaking and a very nice complete kit. Order them yet this week and I will give you free shipping inside Cont. USA.
Ask for Kevin or Tim.
Re: Roller Rockers - what's going on? [Re: Hughes] #170053
12/18/08 07:05 PM
12/18/08 07:05 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Hughes,
Can you give us some basic spec's on the 1506S & 1510S rocker kits? (max spring pressures, max spring od's, etc.)
Do you machine these in house?
What spec of aluminum do these have?
They look like nice sets, are these stock type replacements?
Are they bushed or are they roller bearings?
Re: Roller Rockers - what's going on? [Re: YO7_A66] #170054
12/18/08 07:29 PM
12/18/08 07:29 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I had hughes guaranteed for life billet small block rockers around '01, broke one, and then I was told that they didn't have them anymore. They gave me standard extruded rockers as a replacement, but I lost my guarantee for life...
Just my
Re: Roller Rockers - what's going on? [Re: YO7_A66] #170055
12/18/08 07:48 PM
12/18/08 07:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Hughes,
Not Hughes, but I run them on my Challenger:
- I use them w/ 1.55" OD springs and there is adequate clearance
- Don't know the max pressure, but I'm using them on the street w/ approx. 400#s open on a .600" solid flat-tappet
- They're made by a company that also manufactures rockers for other brands, pistons, etc.
- 2024-T3511
- Stock-type replacement part, although you wouldn't want to use them on OEM shafts IMO
- Neither bushed nor roller bearings; they ride on the fulcrum machined into the main body of the rocker (just like a Crane "gold" rocker)
Re: Roller Rockers - what's going on? [Re: ArcticCuda] #170056
12/18/08 07:49 PM
12/18/08 07:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Step up and get the herland-sharps.....you won`t be dissapointed.
Re: Roller Rockers - what's going on? [Re: Thumperdart] #170057
12/18/08 07:50 PM
12/18/08 07:50 PM
BradH Offline
BradH  Offline
And, then again, you might be...
Re: Roller Rockers - what's going on? [Re: BradH] #170058
12/18/08 07:56 PM
12/18/08 07:56 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have the hughes rockers very nice.I think they are made by probe ind for hughes only.
Re: Roller Rockers - what's going on? [Re: Scamp408] #170059
12/18/08 08:45 PM
12/18/08 08:45 PM
SoCal
Brian Hafliger Offline
SoCal
Crane is changing the design of their mopar rockers and shafts....Comp rockers and hardware is available, just get shafts and assemble them yourself.
Comp won't have shafts for a while...
HS rockers IMO, and from what little I see of them, have a not so great geometry...they like to hang off the edge of the valve tip.
Haven't tried any of Hughes stuff yet, but I have tried Racer Brown's rockers and they are very nice!!
Brian
Brian Hafliger
Re: Roller Rockers - what's going on? [Re: Brian Hafliger] #170060
12/18/08 08:53 PM
12/18/08 08:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My h/s`s did start a bit inboard on the valve tip but after using lash caps, they seem to be fine......many street miles and several passes and all looks well.
Re: Roller Rockers - what's going on? [Re: Thumperdart] #170061
12/19/08 12:11 AM
12/19/08 12:11 AM
SoCal
SoCal
The BB's are better than the SB's...not much but some!
I wish HS would re-design their rocker bodies and do like TD and offer a smaller shaft with sleeves to fit the pedestals and offer 1.7 as a shelf and not a special "lets charge out the ying yang" price!
Re: Roller Rockers - what's going on? [Re: Brian Hafliger] #170062
12/19/08 01:06 AM
12/19/08 01:06 AM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
the HS rockers for a BB are a tad long when used on OE or Edelbrock heads.
still usable, but not the ideal contact pattern.
however, they fit the Indy heads quite nicely.
basically perfect roller placement and plenty of spring/retainer clearance.
the ICH rockers seem to be split the difference in the length between the shaft centerline and the roller tip centerline compared to the longer HS rockers, and the noticably shorter Crane and Comp rockers.
attached is a HS rocker on an Indy head.
Re: Roller Rockers - what's going on? [Re: dizuster] #170063
12/19/08 09:10 AM
12/19/08 09:10 AM
Just my
that would TICK ME OFF!
Re: Roller Rockers - what's going on? [Re: ArcticCuda] #170064
12/19/08 10:37 AM
12/19/08 10:37 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Just for another source, you might try here http://www.rockerarms.com/ I used them for rebushing A set of hemi rockers and I had them hard chrome the shafts. everything looked great and they do have new rockers for sale for several applications
Re: Roller Rockers - what's going on? #170065
12/19/08 01:10 PM
12/19/08 01:10 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Just my
That's only the rocker arm portion of the story, I won't get into the 3 cams...
Re: Roller Rockers - what's going on? [Re: YO7_A66] #170066
12/19/08 01:14 PM
12/19/08 01:14 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
Our rockers are all CNC'd. They are made in the USA. They do not use bushing or needle Bearings. We banana groove the shafts so you get full oil pressure all across the surface of the rocker.
Years ago we sold some rockers made by Dove. They were extrude honed. If Dizuster had one of those and they broke we would have replaced it with one of those or referred him to Dove. The new ones are all CNC'd. For super high spring pressures we suggest having us get them Cryo treated.
Kevin@ Hughes
Re: Roller Rockers - what's going on? [Re: Hughes] #170067
12/19/08 01:20 PM
12/19/08 01:20 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
I have used the Hughes stuff before with 660lbs.+ open pressure and 7800rpm. Never a problem.
Re: Roller Rockers - what's going on? [Re: SuperStocker] #170068
12/19/08 03:33 PM
12/19/08 03:33 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Is hughes going to start making w2/w5 or indy small blk stuff?
