Roller Rockers - what's going on?
#170049
12/18/08 03:33 PM
12/18/08 03:33 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Comp Cams 1321-16 roller rockers has been in back order since August. Now I tried to buy Crane 64792-1 rockers. Answer: Availabele after 7 weeks...
What is going on? Do I have to buy China Rockers.
Pepe / Finland Europe
1970 Plymouth GTX 440-6 1970 Plymouth PPR Cuda 489-4 1971 Plymouth Duster Bad Romance 408-W5 1970 Plymouth Fury III Coupe 383-4
Re: Roller Rockers - what's going on?
[Re: Hughes]
#170053
12/18/08 07:05 PM
12/18/08 07:05 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
Hughes, Can you give us some basic spec's on the 1506S & 1510S rocker kits? (max spring pressures, max spring od's, etc.) Do you machine these in house? What spec of aluminum do these have? They look like nice sets, are these stock type replacements? Are they bushed or are they roller bearings? Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#170055
12/18/08 07:48 PM
12/18/08 07:48 PM
BradH
Not Hughes, but I run them on my Challenger: - I use them w/ 1.55" OD springs and there is adequate clearance - Don't know the max pressure, but I'm using them on the street w/ approx. 400#s open on a .600" solid flat-tappet - They're made by a company that also manufactures rockers for other brands, pistons, etc. - 2024-T3511 - Stock-type replacement part, although you wouldn't want to use them on OEM shafts IMO - Neither bushed nor roller bearings; they ride on the fulcrum machined into the main body of the rocker (just like a Crane "gold" rocker)
[Re: Scamp408]
#170059
12/18/08 08:45 PM
12/18/08 08:45 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Crane is changing the design of their mopar rockers and shafts....Comp rockers and hardware is available, just get shafts and assemble them yourself. Comp won't have shafts for a while... HS rockers IMO, and from what little I see of them, have a not so great geometry...they like to hang off the edge of the valve tip. Haven't tried any of Hughes stuff yet, but I have tried Racer Brown's rockers and they are very nice!! Brian
Brian Hafliger
[Re: Thumperdart]
#170061
12/19/08 12:11 AM
12/19/08 12:11 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
My h/s`s did start a bit inboard on the valve tip but after using lash caps, they seem to be fine......many street miles and several passes and all looks well.
The BB's are better than the SB's...not much but some! I wish HS would re-design their rocker bodies and do like TD and offer a smaller shaft with sleeves to fit the pedestals and offer 1.7 as a shelf and not a special "lets charge out the ying yang" price!
[Re: Brian Hafliger]
#170062
12/19/08 01:06 AM
12/19/08 01:06 AM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
the HS rockers for a BB are a tad long when used on OE or Edelbrock heads. still usable, but not the ideal contact pattern.
however, they fit the Indy heads quite nicely. basically perfect roller placement and plenty of spring/retainer clearance.
the ICH rockers seem to be split the difference in the length between the shaft centerline and the roller tip centerline compared to the longer HS rockers, and the noticably shorter Crane and Comp rockers.
attached is a HS rocker on an Indy head.
[Re: dizuster]
#170063
12/19/08 09:10 AM
12/19/08 09:10 AM
I had hughes guaranteed for life billet small block rockers around '01, broke one, and then I was told that they didn't have them anymore. They gave me standard extruded rockers as a replacement, but I lost my guarantee for life...
Just my
that would TICK ME OFF!
#170065
12/19/08 01:10 PM
12/19/08 01:10 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Just my
That's only the rocker arm portion of the story, I won't get into the 3 cams...
