6.1 alternator bracket (Mike Roth) #1700380
11/18/14 04:09 PM
11/18/14 04:09 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I talked to Mike about the alternator bracket he makes I am pretty sure it will work to run a mechanical water pump and should fit a b body. It uses a small GM alternator (one wire) which should make for a much easier swap. It works with car timing covers and if you have to buy all the factory stuff tensioners, idlers, alt, PS delete stuff you come out money ahead.
Re: 6.1 alternator bracket (Mike Roth) [Re: biff426] #1700381
11/18/14 06:12 PM
11/18/14 06:12 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
That's really nice for the Drag guys. Mechanical or Meziere water pump and go.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 6.1 alternator bracket (Mike Roth) [Re: AlexP] #1700382
11/19/14 01:34 AM
11/19/14 01:34 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
That looks good. Where do you buy one?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 6.1 alternator bracket (Mike Roth) [Re: biff426] #1700383
11/19/14 02:10 AM
11/19/14 02:10 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Can he make one that mounts the GM alternator to the passenger side?
I want to run power steering and no AC
Thanks!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 6.1 alternator bracket (Mike Roth) [Re: RylisPro] #1700384
11/19/14 02:20 AM
11/19/14 02:20 AM
Lebanon,IN
mr2performance Offline
Lebanon,IN
I have the brackets in stock. If you need one give me a shout, or email mr2performance@sbcglobal.net Thx Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: 6.1 alternator bracket (Mike Roth) [Re: mr2performance] #1700385
12/01/14 07:40 PM
12/01/14 07:40 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Here is a picture of it with a factory water pump fits a stock B body K member with manual steering like a glove with no modifications. really cool setup.
Re: 6.1 alternator bracket (Mike Roth) [Re: biff426] #1700386
12/01/14 08:01 PM
12/01/14 08:01 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
That's slick!
Re: 6.1 alternator bracket (Mike Roth) [Re: biff426] #1700387
12/01/14 08:14 PM
12/01/14 08:14 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Is there any issue with belt walking around on the water pump pulley? Seems an idle may be needed maybe?
Mopar to the bone!!!
Re: 6.1 alternator bracket (Mike Roth) [Re: biff426] #1700388
12/01/14 08:16 PM
12/01/14 08:16 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Isnt that spinning the water pump the wrong direction?
Re: 6.1 alternator bracket (Mike Roth) [Re: sixpackgut] #1700389
12/02/14 01:19 AM
12/02/14 01:19 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
The water pump pulley is grooved like the alt and balancer I looked at a factory 6.1 setup and the water pump appears to spin clockwise. With the water pump pulley grooved the belt should not walk.
Re: 6.1 alternator bracket (Mike Roth) [Re: biff426] #1700390
12/02/14 01:27 AM
12/02/14 01:27 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Here is a picture of the front of a factory 6.1 with accessories looks to me like it spins clockwise
Re: 6.1 alternator bracket (Mike Roth) [Re: biff426] #1700391
12/02/14 01:45 AM
12/02/14 01:45 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
5.7 truck motor not like that. Will a 6.1 water pump bolt up to the truck front cover?
Re: 6.1 alternator bracket (Mike Roth) [Re: sixpackgut] #1700392
12/02/14 02:04 AM
12/02/14 02:04 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
No the outlet is on the wrong side and will not work I tried
Re: 6.1 alternator bracket (Mike Roth) [Re: biff426] #1700393
12/02/14 02:23 AM
12/02/14 02:23 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yes you are right, I thought about that later after I posted.
