Leaf spring drill hole ?? #1700345
11/18/14 03:52 PM
11/18/14 03:52 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
This may have been asked before, but ..I want to move the small leaf spring forward..Any problem with drilling a new positioning hole in the center of the spring ??
Re: Leaf spring drill hole ?? [Re: dynamite] #1700346
11/18/14 05:17 PM
11/18/14 05:17 PM
There's no limit on Q's even if redundant. yes you can redrill another hole (across in both vertical walls). definitely do it on a drill press Before you pull it measure how far the leaf eyelet is from the front wall & that'll tell you how much you can move it forward (with a reasonable amt of clearance of course). As you know it'll affect the tire/wheel location in teh wheel well and rear shackle tilt but I'm assuming you have (or will have after redrilling) that covered. EDIT shock lower hole to tapered stud fitment might be slightly more difficult
Re: Leaf spring drill hole ?? [Re: RapidRobert] #1700347
11/18/14 07:18 PM
11/18/14 07:18 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
If your wanting to redrill the center bolt hole, the spring leafs are hardened. They need to be drilled with good bits, lots of cutting oil at a slow pace. You will probably want to pull the spring packs apart and drill on a press, and then your probably only going to want to relocate the main leaf center hole, and shift the other springs to the new hole. Watch the length of the 2nd leaf that its not too long. The end can be cut off with a cutoff wheel and debured. Gene
Re: Leaf spring drill hole ?? [Re: poorboy] #1700348
11/18/14 11:07 PM
11/18/14 11:07 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i have found that a masonry bit in a drill press will cut a nice hole...
Re: Leaf spring drill hole ?? [Re: savoy64] #1700349
11/18/14 11:32 PM
11/18/14 11:32 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I interpreted the OP as wanting to only move a single leaf forward, the smallest of the pack.
Re: Leaf spring drill hole ?? [Re: Kern Dog] #1700350
11/19/14 12:07 AM
11/19/14 12:07 AM
Me too after reading Poorboys' response
Re: Leaf spring drill hole ?? [Re: RapidRobert] #1700351
11/19/14 11:13 AM
11/19/14 11:13 AM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
RR is right ,only the smallest leaf. Thanks for all posts tho
