A727 Transgo TF-2 install #1700287
11/18/14 01:25 PM
11/18/14 01:25 PM
MA
mopar67440 Offline OP
MA
I'm sure this has been discussed somewhere, but couldn't locate the answer.
I just install the TF-2 shift kit in a rebuilt 1971 torqueflite for a 440 I suspect will be around 450hp for street/strip. I've added the shift command feature, and all mods went well. Just hoping to get some additional clarity on a few of the adjustments.
Pressure Regulator Adjustment;
Shims, spring seat, inner spring, and outer spring and valve were replaced per instructions. Transgo suggests 3/16" allen adjustment be backed off until spring seat is just flush to edge of retainer. Factory was 1 5/16". Some forums discuss 3 turns from flush, and up to 6 turns from flush. I'm suspecting this is more for race application. Should I just stick with instructions, and check with a pressure gauge once running? Hate to have to drop the pan again.
Throttle Valve Adjustment;
Transgo kit makes no mention of any adjustment here. Stem end was ground per instructions to 9/32". With the throttle lever touching the stop, I set the clearance to 3/16 using a drill bit. I've read on some forums many adjusting to 1/8.
Orifice Plug;
Not sure if I should install this into the case, but it appears it's used in 80% of the mods.
Any suggestions greatly appreciated.
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700288
11/18/14 01:44 PM
11/18/14 01:44 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I have installed many TF 2's over the years and have always followed their instructions and have had ZERO issues.
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700289
11/18/14 04:59 PM
11/18/14 04:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The confusion arises from the fact that Transgo changes their instructions like I change my shorts (once a year or so).
The older instructions gave a PR spring setting of so many inches, then so many turns and finally flush.
Ditto the throttle valve, it was originally a 1/8" air gap and then no mention.
The cup orifice is a crap shoot, I would install it and remove it only is you experience RPM flareup on the 2-3 shift.
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700290
11/18/14 09:45 PM
11/18/14 09:45 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I personally experiment with the size of the orifice plug. The 2-3 overlap is one of my pet peeves. You can use tiny core plugs to drill progressively smaller openings till you get a flair up, then back up a little. Others may have a better way to get to the sweet spot, but that is what has worked for me. Usually .075-.100 gets the overlap out.
Of course, that means repeated valve body pulls. It is not "one size fits all", so the only way to get it right on any given tranny is to experiment.
Master, again and still
Re: A727 Transgo TF-2 install [Re: DaveRS23] #1700291
11/19/14 03:17 PM
11/19/14 03:17 PM
MA
MA
"Usually .075-.100 gets the overlap out."
Is this the typical range for a band adjustment of 2.5 turns from 72 inch lbs on a kevlar band, 4.2 ratio lever, 4 alto red clutches/kolene steels (not sure of clearance) 12 return springs, and PR adjusted flush to the retainer?
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700292
11/19/14 05:37 PM
11/19/14 05:37 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have never kept track of the combination of factors that results in any given orifice size curing the overlap. I just keep putting in smaller sizes until it just starts to flair, then I usually go back .005"-.010" larger.
It helps to have access to the numbered drill bits because the fractional ones are usually too large of a step between. Although a 3/32" (.094) might be a good place to start.
The .075"-.100" orifice was just a suggested starting range so as to help minimize the number of times you might have to pull the pan.
Dorman 3/8" cup expansion plugs part #555-115 is what I use.
Trial and error is the only way I know to get it right on any particular combo.
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700293
11/19/14 05:47 PM
11/19/14 05:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's hard to predict with any certainty the shift quality of a trans even when the components/clearances are known, that's the purpose of the restrictor orifice....it can be changed without the necessity of removing/disassembling the trans to change the internal setup.
The restrictor supplied with the TF-2 has a .140" orifice and the orifice in the later factory separator plates is .125"
Tapping the case for a 1/8" NPT socket-head plug makes changes easier....drill the plug to the desired size.
Re: A727 Transgo TF-2 install [Re: John_Kunkel] #1700294
11/24/14 04:30 PM
11/24/14 04:30 PM
MA
MA
Where is the later year .125 orifice located in the separator plate? I'm wondering if this is one of the holes that Transgo instructs to open up, then you install a .140 orific in the housing. This doesn't make any sense. Even if not modified, why install a plug with a larger hole than the plate.
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700295
11/24/14 05:01 PM
11/24/14 05:01 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
,140 restrictor doesn't do much for curing the overlap with the tf2 kit; been there, done that. i think most people ignore the heavy throttle pressure spring that's in the kit. that spring, in my opinion, is too heavy and creates issues.
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700296
11/24/14 05:44 PM
11/24/14 05:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, Transgo instructs you to enlarge this hole...the thought being it's easier to manipulate the orifice in the case.
In the pic below D is the front clutch feed (3rd gear) and B is the kickdown servo feed (second gear).
Re: A727 Transgo TF-2 install [Re: John_Kunkel] #1700297
11/24/14 06:28 PM
11/24/14 06:28 PM
MA
MA
The valve body I modified was a 1971 w/ part throttle KD to be used in a 1974 trans that we rebuilt. When I went to mod the VB, we found the seperator plate had some rust & pits in it from water that entered the case. I also discovered a few of the Transgo mods were performed, so we decided it was best to not use the 74 VB and to start fresh w/ the 71 VB.
Per the instructions for high stall convertor, street/strip, & firmest shift, I opened up A, C, D to .187" L looked like it was already opened up by someone to .187" I never thought to check the case for an orifice, but I suspect there was one.
B was left alone and I removed the .125" bearing.
Looks like I definitely need to install the .140 plug minimum.
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700298
11/24/14 07:29 PM
11/24/14 07:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Removing the .250" bearing pretty much overrides the size of the B orifice.
Re: A727 Transgo TF-2 install [Re: John_Kunkel] #1700299
11/25/14 11:37 PM
11/25/14 11:37 PM
MA
MA
ok...so I think I basically have a handle on where this is going. It's really down to taking the valve body for a spin to see what issues if any I might have to deal with(shift rpm at wot in drive...hopefully around 6k based on engine combo, 2-3 overlap or flareup).
Still not confident on the PR adjustment being flush vs the stock 1 5/16". Even Munroe skips this in the TF-2 details. Maybe flush is ok with the added spring tension, and I can always throw a gauge on it to measure line pressure if there are shift issues.
Also decided to simply go with Dex/Merc ATF, and not type F or synthetic.
Thanks for all the help!
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700300
11/26/14 06:28 PM
11/26/14 06:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
PR setting depends on the spring, a stiffer spring allows the adjuster to be flush. Go with the instructions for your kit.
Re: A727 Transgo TF-2 install [Re: John_Kunkel] #1700301
11/26/14 09:30 PM
11/26/14 09:30 PM
MA
MA
Yes I plan to leave it flush for now with the additional spring tension and spacers.
I still find it odd that the kit instructions dated Nov 2011, make no mentioned of an adjustment, and Munroe's handbook 1st edition 2003 where on page 107 the kit install is detailed, there is no mention either. This leads me to believe it's left at the factory 1 5/16". I suspect line pressure then is well over 100 psi with the kit.
That said, what can I expect for line pressure? Stock is 54-60 psi at 1k rpms, and 90-96 psi with TV fully depressed, and f/r servo within 3 psi of line.
Re: A727 Transgo TF-2 install [Re: DaveRS23] #1700302
11/26/14 11:17 PM
11/26/14 11:17 PM
MA
MA
"Dorman 3/8" cup expansion plugs part #555-115 is what I use"
Dave...I like the idea. Certainly cheap and easy enough to drill and install. One question... similar to the Transgo .140 orific, I'm curious how you remove the plugs?
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700303
11/27/14 12:14 PM
11/27/14 12:14 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I screw a sheet metal screw into it and use a claw hammer or wrecking bar to lever the screw out. Quick and easy.
Re: A727 Transgo TF-2 install [Re: DaveRS23] #1700304
12/03/14 12:42 PM
12/03/14 12:42 PM
MA
MA
I ordered 3 of the Dorman plugs, and plan on drilling them out to .125, .110, 095.
Will most likely start with the .125 vs the .140 provided in the kit, then depending on results, make a change up or down.
Thanks for the suggestion.
Re: A727 Transgo TF-2 install [Re: mopar67440] #1700305
12/03/14 10:05 PM
12/03/14 10:05 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Start with the .110. Starting there may save a tear down. Let us know how it goes.
Re: A727 Transgo TF-2 install [Re: DaveRS23] #1700306
12/04/14 05:49 PM
12/04/14 05:49 PM
MA
MA
Will provide an update once the engine/trans are installed and broken in. Should be in the next few weeks. What a xmas present
Any idea on what the Transgo TF-2 kit pressures would be if I throw gauges on the various ports?
