440 Bare Block - What Would You Do? #1700171
11/17/14 08:11 PM
11/17/14 08:11 PM
Tennessee
WyleECoyote Offline OP
Tennessee
1965 440.
I have no information on it.
It has a broken motor mount tab on each side.
What Would YOU Do With It?
single choice
Votes accepted starting: 11/17/14 06:08 PM
You must vote before you can view the results of this poll.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 440 Bare Block - What Would You Do? [Re: WyleECoyote] #1700172
11/17/14 08:15 PM
11/17/14 08:15 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
A racer with a "motorplate" could use it.
A boater with "marine motorplate" could use it.
Re: 440 Bare Block - What Would You Do? [Re: Dean_Kuzluzski] #1700173
11/17/14 08:17 PM
11/17/14 08:17 PM
Tennessee
Tennessee
Ah, touche'. I didn't think about those options.
Thanks!
Re: 440 Bare Block - What Would You Do? [Re: WyleECoyote] #1700174
11/17/14 08:34 PM
11/17/14 08:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Lotta updates done to the 440 block since that one was cast. Dunno if a racer'd want it, unless they plan to hard blok it. Heck, offer it up for sale, if it don't sale then you can scrap it.
Don't be the exception.
Re: 440 Bare Block - What Would You Do? [Re: WyleECoyote] #1700175
11/17/14 08:37 PM
11/17/14 08:37 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Sell it. Someone will want it.
It's not hard to build up the motor mount blocks by brazing with silicon bronze.
- Stu Harmon
Re: 440 Bare Block - What Would You Do? [Re: feets] #1700176
11/17/14 09:27 PM
11/17/14 09:27 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Re: 440 Bare Block - What Would You Do? [Re: fastmark] #1700177
11/17/14 09:28 PM
11/17/14 09:28 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
I agree also, My 340 had this done 20 years ago and still is fine.
Re: 440 Bare Block - What Would You Do? [Re: WyleECoyote] #1700178
11/17/14 09:43 PM
11/17/14 09:43 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I wouldn't sell it. 440s are getting harder to find. At least around here. Someone could use it.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 440 Bare Block - What Would You Do? [Re: JonC] #1700179
11/17/14 11:26 PM
11/17/14 11:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Price it right. Thoroughly describe the damage in your ad. It will sell.
Re: 440 Bare Block - What Would You Do? [Re: DaytonaTurbo] #1700180
11/18/14 02:18 AM
11/18/14 02:18 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
turn it into a table
Re: 440 Bare Block - What Would You Do? [Re: WyleECoyote] #1700181
11/18/14 03:07 AM
11/18/14 03:07 AM
It's rusty and damaged. Baking will (likely) take care of the rust but what condition it is in. (2) as said welding would fix the mounts. I wouldn't use it myself. I'd advertize it as is/honest descrip
Re: 440 Bare Block - What Would You Do? [Re: RapidRobert] #1700182
11/18/14 03:20 AM
11/18/14 03:20 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Probably a couple hundred dollars worth of iron sitting there. Racers cut those off a lot of times anyway.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 Bare Block - What Would You Do? [Re: pittsburghracer] #1700183
11/18/14 02:10 PM
11/18/14 02:10 PM
dogdays Offline
dogdays  Offline
Measure the bores. If it's been bored out 0.040 it is probably pretty worthless. If it's stock bore and has all the main caps it's worth at least twice of scrap, maybe more.
The block weighs around 220 lb. Clean cast iron would have to be over a dollar a pound for it to be worth hundreds.
I hate to see any 440 go away, considering that Mopar made around 3 383s for every 440.
R.
Re: 440 Bare Block - What Would You Do? [Re: dogdays] #1700184
11/18/14 04:19 PM
11/18/14 04:19 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Sell it to a drag racer
2011 Drag Pak Challenger
Re: 440 Bare Block - What Would You Do? [Re: WyleECoyote] #1700185
11/18/14 07:36 PM
11/18/14 07:36 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
where did you find a 65 440 ? first year was 66
Re: 440 Bare Block - What Would You Do? [Re: terzmo] #1700186
11/18/14 08:02 PM
11/18/14 08:02 PM
New York
rarefish Offline
rarefish  Offline
New York
It is most likely a 65 casting date block used in a 66 model year car.
I just had about a dozen 440 blocks from an estate of a friend's that I was selling off. I think about 6 of them were HP blocks. Some were still standard bore. About a week ago a guy came in and bought out the complete estate for one price. A lot of good stuff went out the door in one sweep.
Re: 440 Bare Block - What Would You Do? [Re: rarefish] #1700187
11/18/14 09:25 PM
11/18/14 09:25 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
the pad on the front of the block wil/should have B440 on it....chrysler cars was the only application that year for a 440
