Re: 1-wire or Denso alternator bracket for 383 with A/C....
[Re: upnover]
#1699946
11/17/14 11:32 PM
11/17/14 11:32 PM
Posts: 7,664 IN
ahy
IN
Andy F and Mancini have the kits for non AC cars but I haven't seen kits for "with AC". The fixed alternator mount spacing and extra bracing "with AC" greatly complicates fitting a non standard alternator. I wound up going with the "big Chrysler" alternator from my core engine ('78 Cordoba with a 400). Plenty of juice but very heavy. An alternative I am considering is a "mean green" alternator. Nacho found this one. They apparently offer a 160+ amp alternator that fits in the space of a squareback. A second alternative is adapting the "big Chrysler" brackets to a Nippendenso. http://shop.mean-green.com/main.sc
[Re: upnover]
#1699947
11/17/14 11:32 PM
11/17/14 11:32 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
If you wish to stick with the v-belt Mancini sells a set that Andy F makes, link shows a kit, but I've bought just the bracket kit. You may need to call them. HTH, Steve
