Re: TTI vs Doug's headers
[Re: lewtot184]
#1699921
11/17/14 12:48 PM
11/17/14 12:48 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
I put Doug's on my 70 4 sp road runner. No real problems and they work great. I went back and looked it up I do have Doug's
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1699922
11/17/14 01:35 PM
11/17/14 01:35 PM
Posts: 1,436 Oklahoma City OK
Cudajon
Oklahoma City OK
I'm running Doug's Headers "452" on my 493 in a 72 Cuda. Had to massage the header where it passed the steering column. These are 2" primarys forget ever being able to access the starter in car, I'm running a denso off of a dakota so its the small starter, still impossible to remove once in car. I drop the engine in with the starter already mounted, still takes a while to access wiring etc. I recently added power steering for my wifey, these headers are not designed to work with it and I put the steering box in with the engine in the car, otherwise I couldn't have done it. It touches the header and I had to massage it to fix that. I run jacobs spark plug wires with the ceramic boots after burning up several other brands, its the only ones I've found that will work without those nasty looking shields. The headers work great but I'm disappointed the ceramic coating started going away within a year. I can't say anything about the TTI's, but I do run the TTI exhaust system all the way back with the 3" pipe. That's a nice setup. I also run a cross pipe like came on the Hemi cars back in the day, whether it adds anything I don't know. The exhaust is so large I think any benefit it gave the hemi cars is lost. Hope this helps in your decision. [image] [/image]
[Re: Cudajon]
#1699923
11/17/14 01:55 PM
11/17/14 01:55 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
i use the DOUG'S "452" in my 70 runner 440 6pak, 2",fit is perfect, no more burnt plug boots, easy access to plugs, the heavy flange i think is key to them be leak free,got the ceramic coated and 2 years later still look new, i have no power steering and mine is an automatic, but they are a perfect fit, i did tilt the motor to drop in passenger side, but never even scratched the paint installing
[Re: stateroadhog]
#1699926
11/17/14 04:30 PM
11/17/14 04:30 PM
Posts: 27,472 So Cal
autoxcuda
So Cal
Remember Dougs and Doug Thorley are two different companies. <Edit> Forwardlook seems to have a straighter timeline on this confusing deal. </Edit> I have not used either. I thought the consensus was one was a little better?? Or might matter product by product??
[Re: meepmeep70]
#1699927
11/17/14 04:32 PM
11/17/14 04:32 PM
Posts: 3,515 Turku, Finland
Forwardlook
Turku, Finland
Yeah, two diferent companies. Here is a short timeline regarding Doug's and Doug Thorley. Posted on HAMB.
"Actually here is the real scoop. The original company that Doug Thorley started was a muffler shop back in 1958 in East LA. In the early 60's Doug started to make headers and "Headers by Doug" stickers started showing up on winning drag cars. Doug and wife Betty sold the company and got divorced and new owner Micky called it Doug Thorley Headers. A number of years went by and Micky got sick and asked for help. Betty came back in to run things and Micky got worse. He ended up selling the company back to Betty, Doug and a third partner. Doug mainly did R&D and was an investor. Eventually He and Betty had another falling out and she agreed to buy him out. Doug kind of stayed away at this time, occasionally coming around to help out with a little R&D and collect his payments. Betty then got sick and at this time Doug started doing custom headers again under the Doug's Headers name. During this time Doug Thorley Headers was mainly making truck and motor home headers, not muscle car or performance parts. Betty passed and Doug started making production headers again for the classic and muscle car markets. After about another year, the surviving partner sold Doug Thorley Headers to Summit Industries (not the mail order guys) in Corona, Ca who previously had bought out Jerry Jardine of Jardine Headers. PerTronix, who had previously acquired Ermie Immerso Ind and Thunderbird Headers bought Doug's Headers and Doug worked to help keep the Doug's Headers line a top quality product. PerTronix sells and manufactures them as a premium line to compliment their Patriot Header line. They are currently made in Rancho Dominguez (think north Long Beach) CA. Doug was also famous for his drag cars - The Chevy II Much that is in the NHRA museum, the Funny Car Corviar that Joe Piasano ended up with, and the pair of rear/mid engined Javelin's."
[Re: ahy]
#1699930
11/18/14 02:48 AM
11/18/14 02:48 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
By the way the TTI's in the pic on my 63 are the cheapest way you can get them as I bought them with no coating as they are nickel plated. You can get them with 2 different coatings on them but these are over 3 years old and holding up ok with no coating added. They started blueing just a little but the coated ones wont. Ron
[Re: jake4cars]
#1699934
11/18/14 10:15 PM
11/18/14 10:15 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have Doug's D452 headers on my Savoy with Indy EZ heads and they fit perfect and the coating is still nice. The angle plugs on the Indy heads might provide extra clearance but my Firecore wires fit perfect as well not even close to the 2" tubes. The only fit issue I had was the grease fitting on the pitman arm was dragging on the bottom of the pipes. I had to remove the fitting and all was well My combo also has an 11" 143 tooth wheel and a steel clutch can I had to notch the lip for tube clearance. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1699935
11/19/14 02:09 PM
11/19/14 02:09 PM
Posts: 1,318 Ohio
jlatessa
Ohio
I have noticed that there is a big difference in headers regarding primary lengths, i.e. some not anywhere near equal, nor is there a choice in many brands for primary lengths for RPM considerations. I always thought equal length primaries were an advantage for scavenging or is this a non-issue for a street/strip engine?? Wade in guys!! Joe
[Re: THESHAKERPROJECT]
#1699937
11/19/14 05:03 PM
11/19/14 05:03 PM
Posts: 3,916 usa
lewtot184
usa
I have installed 5 different brands in 69-72 e and b body and by far the best fit is TTI when you consider wires and starter issues . I actually ran stock manifold type firecore wires on my TTI header B Body and with 100+ drag strip passes never burnt a wire or starter. After 10 years the coating still looked new and they never leaked. You can lower you motor on the K frame out from under the car with TTI headers still on the motor too . Pay a bit more for them and be happy. There is a reason they cost more, they are the best !!
x2!!!
