Truck V-10 bellhousing pattern #1699869
11/17/14 01:59 AM
11/17/14 01:59 AM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
Is the bolt pattern on a V-10 truck engine able to be adapted to a small block bell housing? For some reason I think the V10 is similar to a Cummins diesel pattern-SAE. I have a truck with an LA 318 that uses the bell housing for a rear motor mount with a NP-435 transmission and would like to retain it if possible. The truck is a 2-1/2 ton cabover I was thinking of putting in a Magnum 5.2,but sold the donor truck.I then thought since going through a swap,why not a V10 instead!
RT
Re: Truck V-10 bellhousing pattern [Re: RTSrunner] #1699870
11/17/14 02:56 AM
11/17/14 02:56 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
IIRC, the V 10 is the same as an LA.They just added 2 more cylinders.Had one and all the water pump stuff etc was just like SB.
Re: Truck V-10 bellhousing pattern [Re: RTSrunner] #1699871
11/17/14 04:47 AM
11/17/14 04:47 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I thought the V10 and Cummins had the same bolt pattern
Re: Truck V-10 bellhousing pattern [Re: WO23Coronet] #1699872
11/17/14 05:18 AM
11/17/14 05:18 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Could be, never took mine apart.It did appear to use the mini starter like the 5.9...
Re: Truck V-10 bellhousing pattern [Re: WO23Coronet] #1699873
11/17/14 05:23 AM
11/17/14 05:23 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Wikipedia says you are right.And there is a bell on Flea bag right now advertised as 5.9 cummins AND V10 gas.
I stand corrected.Apologies
Re: Truck V-10 bellhousing pattern [Re: WO23Coronet] #1699874
11/17/14 03:01 PM
11/17/14 03:01 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
From what I've read this is correct.
Moparlee
Re: Truck V-10 bellhousing pattern [Re: Robbins] #1699875
11/17/14 03:17 PM
11/17/14 03:17 PM
Guitar Jones Online laugh2
The Viper V10 also has the same bell pattern.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Truck V-10 bellhousing pattern [Re: RTSrunner] #1699876
11/17/14 03:29 PM
11/17/14 03:29 PM
Pittsburgh,PA
Pittsburgh,PA
I've seen v10 engines for sale from trucks converted to diesels that's why I was wondering about the bell pattern.The diesels apparently use a SAE bolt pattern,#3 or 4 I guess years may be different.I did find some bell adapters from SAE to small block Mopar.A flywheel spacer may be different for the v10 vs diesel though.
http://www.phxgrp.com/transChrysler.htm
Thank for the replies,RT
Re: Truck V-10 bellhousing pattern [Re: Guitar Jones] #1699877
11/17/14 07:14 PM
11/17/14 07:14 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
That is incorrect. The aluminum viper V10 uses the normal small block bellhousing pattern. The iron block truck V10 does use the cummins SAE bellhousing.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Truck V-10 bellhousing pattern [Re: blown340] #1699878
11/17/14 07:40 PM
11/17/14 07:40 PM
-Jon
The ones I worked on didn't have a SB block pattern, they look more like the V10 and Cummins although I never measured or tried to bolt one up.
Re: Truck V-10 bellhousing pattern [Re: blown340] #1699879
11/18/14 05:38 PM
11/18/14 05:38 PM
Well after further research I've found that both of us are wrong. The Viper V10 uses a pattern similar to the small block but the bolt holes do not line up, apparently it's one all it's own, why they did that I have no idea. I put a clutch in a '92 a long time ago and it didn't look like a SB pattern to me but I guess it's similar.
Re: Truck V-10 bellhousing pattern [Re: Guitar Jones] #1699880
11/20/14 02:42 AM
11/20/14 02:42 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
gas truck v10 and cummins are identical and are not an SAE pattern---i have heard the viper motor is also identical because the cummins 727 (89-91) is being on the viper motor for drag racing.....
