Comp Cams KD516 Pushrod cutter sizes #1699434
11/15/14 10:11 PM
11/15/14 10:11 PM
Western PA
O
OldMoparMan Offline OP
O
Western PA
Has anyone here used a Comp Cam KD516 5/16" pushrod cutter. I made a slide hammer slug and removed the cups from mt 7821 5/16" pushrods so I can shorten them but when I checked the shank section it measures .205 and the pilot is .197 but the KD516 tool shows these sizes (.169 bore, .157 pilot)
I'm confused on these size differences
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: Comp Cams KD516 Pushrod cutter sizes [Re: OldMoparMan] #1699435
11/16/14 01:21 AM
11/16/14 01:21 AM
IN
ahy Offline
ahy  Offline
IN
When I was getting my engine assembled by a race oriented machine shop, I asked if they used "cut to fit" pushrods. "No we order them". If you know the length you need, Comp, Summit or others likely has a stock length that will work. Or Smith Brothers can make a set in a couple of days to whatever length you need. Summit brand "order to length" looks like it starts at $60. Comp is higher. May be a better option vs modifying the ones you have.
http://www.summitracing.com/search/part-type/pushrods-assembled?N=4294894148%2B4294887772
