SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? #1698904
11/14/14 01:05 PM
11/14/14 01:05 PM
NW Chicago suburban area
Mopar Mitch Offline OP
Are there any small block aluminum heads on the market that appear relatively stock, for example, from the outside, having the front/rear, with the core plugs? Without those plugs, its a dead giveaway that the heads are aluminum.
I'm aware that the BB heads have some stock appearing aluminum heads (from the 440-Source company?).
T/Anks ahead!
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: Mopar Mitch] #1698905
11/14/14 01:40 PM
11/14/14 01:40 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Nothing comes to mind
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: Mopar Mitch] #1698906
11/14/14 03:04 PM
11/14/14 03:04 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
"stock appearing"?
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: Mopar Mitch] #1698907
11/14/14 03:08 PM
11/14/14 03:08 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Nope! And every one will jump down your throat here for asking about one
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: jcc] #1698908
11/14/14 03:09 PM
11/14/14 03:09 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Battens come to mind.
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: B1MAXX] #1698909
11/14/14 03:20 PM
11/14/14 03:20 PM
Guitar Jones Offline
Just get some iron W2's if you want performance and the stock appearing look.
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: B1MAXX] #1698910
11/14/14 03:24 PM
11/14/14 03:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yeah! Good luck finding some of those
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: HotRodDave] #1698911
11/14/14 07:56 PM
11/14/14 07:56 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Mitch the only performance head besides some of the W2, that look somewhat stock to me is the iron head RHS X head. You could probably fill in the RHS on the head with JB weld, it's a nice close chamber head but not aluminum. Mike
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: Mopar Mitch] #1698912
11/14/14 08:10 PM
11/14/14 08:10 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Define stock appearing.....
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: Guitar Jones] #1698913
11/14/14 09:45 PM
11/14/14 09:45 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
+1
Especially if you get an older casting that doesn't say W2 on it
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: SpareParts] #1698914
11/15/14 02:14 PM
11/15/14 02:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The answer to your question is "There isn't one"
There are a couple candidates that get close, neither has been manufactured for many years, and both are fairly rare to find.
Batten Heads: While not an exact match to factory 915 castings, these looked the most like stock castings, water jacket plugs in the ends, rough cast ends, etc. they would fool most anyone if painted orange. These were made back in the 1980's or there about, no longer made. They had some pretty well known casting issues, porosity, leaks, etc. Some were good, some were junk, total crap shoot. Most I've seen were already ported by someone, again, total crap shoot, it either improved them or turned them into junk.
Diamond W2 heads: These have rough cast ends which resemble cast iron when painted but lack the core plug on the ends that stock heads have, again, you'll fool a lot of people with these but sharper eyed Mopar guys will spot the lack of the plugs. These were made my Diamond Racing products back in the 1980's (Diamond is still in business making pistons but not heads). These were in the Direct Connection catalog for sale to racers back then, VERY expensive for the day, and good castings, the flowed BIG numbers if given even a mild port job. There were some reports of some porosity issues but I've had a few sets of these and all of them so far have been beautiful. Same story as Battens, hard to find, often ruined by previous porting efforts, etc.
The typical racer mentality seems to be "Who cares what it looks like if it works" but I feel there is a good potential market for a stock looking aluminum head, there are a good number of guys that I know whom would like to keep their car looking stock but would like to improve the performance.
*Batten heads shown on this engine
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: ScottSmith_Harms] #1698915
11/15/14 02:15 PM
11/15/14 02:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Diamond Heads
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: ScottSmith_Harms] #1698916
11/15/14 02:15 PM
11/15/14 02:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Diamonds 2
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: ScottSmith_Harms] #1698917
11/15/14 05:10 PM
11/15/14 05:10 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Cast Iron W2 for comparison
Note: not an 'end shot' but best one I have, looks pretty OEM in the most aluminum heads are slab sided like a bar of soap and easy to spot.
WIZE
In Car:
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: J_BODY] #1698918
11/15/14 06:25 PM
11/15/14 06:25 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
And whom are you trying to FOOL ???
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: JohnRR] #1698919
11/15/14 07:31 PM
11/15/14 07:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
With some splash-zone epoxy and paint anything can look stock.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: ScottSmith_Harms] #1698920
11/16/14 12:09 AM
11/16/14 12:09 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
W2 iron head end view
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: pittsburghracer] #1698921
11/17/14 04:25 AM
11/17/14 04:25 AM
JohnRR Offline
JohnRR  Offline
Until you hit a certian ET and they start looking under the valve covers for casting numbers and looking of ALum part that should be iron.
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: JohnRR] #1698922
11/17/14 11:47 AM
11/17/14 11:47 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Right, you won't likely be fooling anyone in FAST or Pure Stock racing, but if you just want a stealthy street car, the above options are all there is.
If someone were to make some SB aluminum heads along the lines of the 440Source Stealth heads that looked something like Battens I'd buy a couple sets for sure.
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING? [Re: ScottSmith_Harms] #1698923
11/17/14 05:25 PM
11/17/14 05:25 PM
Thanks to all for their feedback, tips, suggestions, and 2-cents. etc.
